This is a hard one to answer as it depends on your level of "DIY", I wouldn`t think twice about changing the springs, shockers whatever but you do need the right tools for the job.
The hub clamps the strut at the bottom. This is intentional. A splitting tool is required to release the strut.
Another think to metion when lowering an A3 is to loosen the rear trailing arm main bolts when the car is on the ground and then retighten them. The reason being that when the car is lower the rubber mounts twist. They need resetting otherwise they can split and wearout sooner.
