Page 1 of 2 12 LastLast
Results 1 to 40 of 46
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Exclamation 2001 (y reg) a3 1.8t red oil light with 3 accompanying beeps!
    Hi guys, I've searched the forum and read all of the posts surrounding this issue and ive had some 'oh s***' moments and some releaved sighs with some threads.. First I will explain the problem... My car was serviced last month so oil is full and clean. The red oil can followed by 3 beeps first came on after heavy cornering which s*** me up abit I must say, so I pulled over and restarted my engine, it stayed off for 2 mins then came back intermittently when over 2k rpm. The engine does not sound any different after the final 15 mile crawl home... When I parked up, the light disappeared, I revved it up a few times to about 3.5k rpm and it still didn't come back on... I then took it out for 5 mins at which point after the first 2 mins it came back on all the way till I got back home. I've made the hard choice to put it in the garage and leave it until I know what I'm looking for! Can you guys give me any cheap starting points to look at before pulling the big guns, but just incase it comes to it... I've read that it's unlikely to be a faulty pump but it could be, if this is the case does this engine need to be lifted to replace? Or can it be fixed without removing the engine? If anyone has had this done or roughly knows , and could give me a maximum spend for this situation/fix then I can be prepared for the worst! Thankyou so much for reading this thread, any help would be much appreciated! Sorry for the long winded explanation!
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    It sounds like an oil pressure fault which if it has been driven for any length of time whilst having low pressure could cause catastrophic failure :-(
    First thing I'd check is fault codes and the oil pump pick up pipe in the sump as these are prone to blocking
    Hopefully it's not caused any damage and best of luck 
    I am here: http://maps.google.com/maps?ll=51.791751,0.646581
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    I had the exact same problem with my mkiv golf 1.8t and I did nothing for a few days while trying to get it in to the garage to get it looked at as it was a very intermittent fault and in the end the oil pump failed before it got to the garage to get checked (only 3days went by from fault to failing pump). I sold the car to my brother inlaw and it cost him £2k to put right. So I would say get it checked out as soon as.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Thanks for the replies, I only drove it about 17 miles or so after the light came on, 15 miles of which I thought the light was just oil level so I didn't figure it would do any damage until I got home. Would this fault just have happened as soon as the light came on or could it have been getting worse and doing damage before the light came on? Ive driven the car about 2000 miles in the last 3 weeks and its seemed to run sweet as anything... only thing I noticed was the clutch was a little stiffer than normal, which I was going to sort first thing in January...
    Shame this thing has just happened to be honest, but lucky at the same time! I was going to get it chipped mid January and id just ordered new disks and pads... If this had happened after spending money on chipping it, I would have been thoroughly p****d off xD
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Had tis problem on and off over a space of about two weeks last year. Me knowing bugger all! I just thought. It was a fault in the dis or something. Until it sounded like a tractor as I pull away from a set of lights. Turned out to be a the pickup. Totally clogged up. Luckily it went on me when it did or it may have been very expensive. I'd get it looked at ASAP mate before you bugger your engine.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,906
    Visit 16Klappe's Instagram Channel
    Everybody loves a good old bit of doom and gloom!
    What sort of mileage and service schedules have these cars been on?
    I quite often say I'm going to do things.
    Then never do them.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I bought the car 3 months ago on 108.5k its now neerly ticking over to 112k. The car has had every service on time and was last serviced just over 4 weeks ago... I don't like doom and gloom personally but I'd rather be prepared for the worst on this case!
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    How likely is it to be something as simple as cleaning the sump and pick-up pipe? I could do that myself,but if it turned out to be something else is have equated money on fresh oil..
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Quote Originally Posted by metromaster View Post
    Its worth while if you can do it yourself as blocked pickup is very common.
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    I'd say more than likely after a search on here. And for what it cost well worth a try mate. When I Shan a torch down mine I could only see about two beams of light shining through the gauze. The new one was like turning the big *** light on . Had mine done at the local approved as I was under the impression it was done for. Cost Me £128 labour, parts, oil and engine flush. I was expecting to replace the engine so win win.
    Jardo mine was on 97k at the time and had been on long life service before I got it. Obviously a major factor.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    The long life servicing is the killer I think! I do my cars every 8K or 12 months, 10w40 Quantum, new magnetic sump plug and the cheapest filter I can find. My car is just turning 200k and is perfect, the thing to take from threads like these are that regardless of what you use the timings of the service are key.
    Bad luck with yours, personally I would do the pickup asap and if that doesn't cure it then get it into a specialist for a proper investigation.
    Then never do them.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Well, ive got a Haynes Manual, some ramps, and some tools. as well as my friends dad (if i need him) whos an engineer at Cummins train engines so he might come in handy... so all I need is oil, some of the right silicone sealant, carb cleaner an old toothbrush (ill borrow the misses's and put it back after xD)
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Sorry for random spelling, auto correct on my phone does my nut in xD
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    For what it cost dude get on to tps or someone and get a new pick up pipe in. Think they are around £25ish. Flush it out then whack the new oil and plug in. I was told to change the oil again after 2k. Car been sweet ever since.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Can you use TPS for none trade? there's one in Coventry which is only 25mins away from me but I wasn't sure if I could use them to pick up some parts! If I can I might as well pick up some other bits and pieces whilst I'm there...
    Nov 2010
    1,673
    Yep tps is open to the public
    Sep 2009
    Essex
    2,366
    whilst the sump is down, wire brush all the burned on crap out of the sump too, ie get it back to bare metal.
    sadly the top end is highly likely to be heavily contaminated too so is unlikely to ever be truely quiet
    as for INTERMITENT, its not intermitent. if your pick up is blocked your running in low pressure, if the warning has come up, youre on the cusp of no pressure thereafter until you sort the pick up
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Thankyou for all of your replies! I have been reading up on different oil to be used in this engine, the database in the garage said 10w40 but I've read elsewhere never to use semi synthetic in this engine? What do you guys use? I kinda trusted this garage as it's been recommended by a few people, but I'm worried they have buggered my engine... Should flush it through with some cheap fully synthetic and some engine flush before putting some decent fully synthetic in? What engine flush should i use?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Quantum Platinum 10w40, it's available from Audi/VW or GSF and is cheap and good.
    Then never do them.
    Aug 2009
    Costa del Cardiff
    535
    Is there no way to check the condition of your pick up pipe yourself, mines just ticked over 105k, although been on regular 10k/12 months service, I'd like to make sure it's virtually clear of any build up.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Could be just the switch
    I had the same problem even with the oil pump changed i was still getting it but I've changed the look and sensor and all is well now
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by JoeD View Post
    It's more to do with the metal gauze that's on the end of the pick up.
    It has small holes that "can" become blocked.
    IMO if in doubt replace it.
    Pat
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    The pick up pipe IIRC only costs £9 but the poxy o ring is £2.50 ish for a bit of rubber lol
    I am here: http://maps.google.com/maps?ll=51.741161,0.687367
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Aye, well i've got the ramps and some gasket silicone... Its weird how... the previous two services its had fully synthetic oil, the last one it had 10w40 and this happens.. should I stick with fully synthetic? Ive read that you can use 5w40 fully synthetic, does this sound okay for this engine?
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Aye, drop the sump and take the pick-up pipe out and have a look... if in doubt read this thread S3 Sump Removal and Refit (with pics) if not, the Haynes manual has it all in. *edit* its going to be a dirty job, on my mums garage floor... xD oh well
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Quote Originally Posted by StaceyS3 View Post
    Shame theres no where open untill after new year... poor excuse for specialist car parts dealers to have a holiday imo xD
  28. #27
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Right, spent most of the day on my back with my sump playing hard to get, finally got it off, it was the worst sight, but after a good 3 hours of cleaning and two trips to TPS later, a new oil-pickup has been fitted and sump back on, an engine flush and £50 later, my a3 lives and runs smoother than ever!
    I would like to thank everyone who has given me pointers to help me!
  29. #28
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Good work that man! This is what we like to hear, more people picking up the spanners and working on their own cars.
    Then never do them.
  30. #29
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I
    Quote Originally Posted by 16Klappe View Post
    This has given me so much pleasure, think ill have it up on the ramps more often, got new disks and pads coming soon so ill do that myself. I think ill leave the cv boot to a garage, but what do you think to replacing the anti-roll bar links? Is it an easy job?
  31. #30
    May 2009
    Midlands
    197
    Was the pickup blocked? Any pics??
  32. #31
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Shon a torch down and couldn't see any light at the end of the tunnel so I do belive so yes xD I've got some pics of the sump but I'm on my phone at the moment so ill post them when I am. I still have the pick up so ill get some pics when I get back home.
    One thing though, if your going to do this, do it yourself, a garage will not scrub the sump and do a good job! I saved a lot of money doing it myself, garage was going to charge £110 for diagnostic and then labour and parts on top... Got oil and pick up for £36 from tps and just used a scouring pad to do the inside of the sump! Don't use anything abrasive around the face of the sump that joins with the engine.
  33. #32
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    I
    If you mean drop links, then yeah it is super easy. Less than a 10 min job
    The way I see it is if you know your limits, only take off what you can put back on you won't ever go wrong. And if it doesn't work you can pack it all up and get a garage to do it. Then you can go down the pub and tell your mates how you fixed it lol
    I'm going round to Prawns today to do new top mounts and track rod ends, fit a new exhaust hanger and change my turbo bolts. I do all my own stunts
    Then never do them.
  34. #33
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Sounds awesome, talking of turbos I reckon I've got a boost leak but no idea how to find it. The tubo spools then drops then spools again a few times through the Rev ranges, the fix I did yesterday acctualy stopped this happening then it came back after 20mins of driving? Any ideas?
  35. #34
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    this was my sump and pickup when i did mine, it was a bit of a mess
  36. #35
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Is the car mapped or standard? Manual boost controller fitted? Any "upgraded" N75 valves?
    Then never do them.
  37. #36
    May 2010
    Bedford
    2,877
    5W40 quantum platinum would be better than 10w40 but also VAG say that 5w30 can be used in all VAG engines over the year 2000. Pick up is £9.88 inc vat, seal is £3.79 inc vat.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  38. #37
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    He's already done it dude, and personally 5w30 would only go in my car over my dead body! Oil pressure fail!
    Then never do them.
  39. #38
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    My car is completely standard at the moment, I was waiting till after the new year to start work on it properly, I got recommended 5w40 for the winter so that's what I've stuffed in it at the moment. I'm going to swap it out in 1k because it was pretty gunky in there so ill try and get it all out. Can you get 10w40 fully synthetic?
    And thanks to danger s3 for the great guidelines helping me sort this!
  40. #39
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    If you have got boost fluctuations then get it fault code checked on VAGCOM, my money is on either a worn DV or a boost leak. First port of call would be the hoses under the inlet manifold
    Then never do them.
  41. #40
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    There are no error codes atall, everything checks out, had an obd2 plugged in for the 100 mile drive home last night and all the figures add up! I've heard if you spray carb cleaner on the pipes whilst its turned on indicates any leaks, as you get a rev spike when/if it gets sucked into the engine, this sound safe to you?
  1. Oil pressure light is on & three deadly beeps!
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2011, 22:20
  2. Oil Light turned red and started flashin
    By spliffey in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2010, 11:41
  3. Red light in door not red
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th December 2009, 16:49
  4. Red S3, black rims, tints 58-reg
    By redbutcher in forum Spotters forum
    Last Post: 9th June 2009, 22:24
  5. Red oil light
    By daz2347 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2007, 23:06
Tags for this Thread
