EM TuningVolks Autos
Results 1 to 10 of 10
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Testing my ultrasonic cleaner :) HELP
    Hi all merry christmas and all that. So im sad enough to still be lurking asn and i though hi ho ill give my new ultrasonic cleaner a blast, so im using water and a drop of fairly liquid but the theing is buzzing like mad lol is that normal? And when i do my injectors should i just use water? Thanks for helping a slightly merry child with a new toy
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,078
    Buzzing is normal, don't worry. I got my dad one for Xmas, and I'm already sick of the noise!
    I used the proper 'James: sea clean' solution when I did my injectors. Not sure I'd want fairy inside them, so perhaps just warm water.
    I'd give them at least 3 cycles of 5 minutes, with clean water each time
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,078
    Nov 2010
    1,673
    Thanks for that dude, its a really handy bit of kit tbf, not sure about the 1000 uses but iv already cleaned jewllery and cds what other components of the 1.8t can benifit from a blast?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,078
    Worth bashing your FPR in there whilst you've got it all apart I reckon
    Nov 2010
    1,673
    Old topic but i was wondering how to pull my injectors out? Take it that un plugging the battery and take the petrol feed pipe off is the basics but do the injectors just pull out? Or is there clips to be pressed in then pull? A linkey would be nice please as my laptop is out of reach and search is poo on tapa talk, thanks for any help.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,078
    run the engine and pull the fuel pump fuse, think it's no27. that'll de-pressurise the system.
    Then just undo the 5mm allen bolts that hold the fuel rail down, remove the wiring loom, and pull it off!
    the injectors will come out in the rail, then there's 4 little clips to pull the injectors out of the rail
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,167
    By the way. I used washing up liquid on injectors when I leant someone the proper solution. They were fine.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2010
    1,673
    Wiked, shall do this the weekend
    Nov 2010
    1,673
    Quote Originally Posted by Westy View Post
    Ahh good to know, the instruction manual says to use 3 quaters water and 1 1/4 washing up liquid.
  1. Ultrasonic cleaner going cheap :)
    By camscockle20vT in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2011, 11:41
  2. testing testing 123
    By mkimjoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 08:24
  3. Got my ultrasonic cleaner
    By Bignick in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2011, 19:21
  4. When ultrasonic cleaning injectors...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 17:47
  5. PAT(Portable Appliance Testing) testing.
    By jojo in forum General Chat
    Last Post: 24th January 2011, 23:01
