JMB RetrofitsChris Nott
Results 1 to 9 of 9
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    VCDS logs - sorry guys, short one I promise!
    Hi guys,could someone take a look at the following logs for me? I've been worried about the map since having it done at AMD, but this looks OK for a map, not very good for a map and B5 TIP? Thoughts please!
    https://docs.google.com/spreadsheet/...nFneF9DVmxmZ2c
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Loosing boost from about 5k on... request is just over 1.2bar but struggling to make 1bar... boost leak?
    <tuffty/>
    JD09's Avatar
    Dec 2009
    3,080
    Cheers Paul, what's the best way to check?
    RIP S3dave
    May 2004
    nr Glos
    7,177
    leak tester or smoke test for starters if you have anyone local who can do this for you?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    JD09's Avatar
    Dec 2009
    3,080
    Thanks bill. Not sure but will ask around. Failing that I know AMD do them and they're 30mins away. Many thanks team!
    JD09's Avatar
    Dec 2009
    3,080
    Hi guys. Sorry to bump this and this is by no means me arguing!!
    However, after eking told AMd don't do testing at weekends (I can't do weekdays) I contacted a local specialist called Peter Norris. They told me that a boost leak would show up on the dash as an error. But he also stated that if the car wasn't boosting I would need a new turbo. If the car drives fine, I'm chasing ghosts and should save myself some money...
    I presume that is just a lack of understanding??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by JD09 View Post
    Will only show up on the dash if the long term trim is pulling 25% or more fuel out to compensate... I would not bother going to 'that' garage based on that advice...
    Get yer arse down to Glos and let Bill have a look
    <tuffty/>
    JD09's Avatar
    Dec 2009
    3,080
    My next phone call!! Worried that AMD have just fitted the TIP badly. The car made 225.7 on their rolling road, but then 240 after a map and having the TIP fitted... Cheers again PAul.
    JD09's Avatar
    Dec 2009
    3,080
    Sorted. Finally! Went out with a local audi knowledge bank logging the car. Saw about 204g/s. didn't think it looked like a boost leak as was holding steady. Decided to change the maf for a spare he had (from his 500whp b5 s4!!!) and voila! First run saw 223.3g/s!
    So Bill, if you're reading this, thats 279 indicated hp from VCDS logging on an AMD mapped car with b5 tip v1 and Jetex!!
    I'll get some logs when my lead is returned to me.
  1. Last SDS Questions I promise...
    By welshwoody in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2011, 14:14
  2. Price Promise!
    By AwesomeMike in forum Awesome GTI
    Last Post: 16th December 2010, 16:30
  3. VCDS Block 120 Logs on the S3 after Bluefin
    By terrymcg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2010, 09:52
  4. MAF and Boost VCDS Logs, what to you think of mine?
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 15:17
