AH FabricationsBadger5
    May 2010
    Staines Middlesex
    131
    electronic boost controller???
    have been trying to find an electronic boost controller for the 8L can only find manual ones.
    anyone fitted an EBC?
    if so which ones best to go for?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by tyson View Post
    First question is why?
    There is no EBC for the '8L' as they universal but having run both EBC and MBC in the past for various reasons there is no advantage to running either as N75 control is more than capable...
    Only time an EBC would be advisable is if you are running big turbo in a FWD A3 and then you would use something like an Apexi using the gear limit control to get the power to the ground more effectively
    Have used MBC's in the past to cap boost spikes on dodgy maps and the like but thats more a sticky plaster than a fix...
    If you plan to try and use one to get more boost than you currently have then this will most likely end in the ECU going to limp mode..
    <tuffty/>
  1. Would an electronic boost controller solve my problem? Help please?
    By B5QUAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd December 2011, 12:31
  2. Which Boost controller????
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2011, 14:05
  3. Boost controller yes or no??
    By bp1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 13:56
  4. electronic boost controller on remapped s3
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 14:53
  5. boost controller
    By s3ollie in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2007, 21:55
