Volks AutosAH Fabrications
Results 1 to 13 of 13
Thread: lean on boost
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    lean on boost
    on light throttle and idel runs perfect between 14.6-15.1
    on boost (anything over 4PSI) will drop straight to 10.0 (lowest the gauge will go)
    i've got a "stage 1 remap" which will be a generic map
    would it be worth spending money on getting a custom map done to make it run correct or just wait until i fit my K03S on then get a custom stage 2 map
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    beachbuggy's Avatar
    Surrey
    1,744
    Faulty fpr could be the cause.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    if i'm going to replace it would it be worth sticking a 4 bar one in for future mods or just replace with another 3 bar
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Is this a proper wideband guage?
    10.0 is rich, not lean.
    TD5 Land Rover Defender build
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    10:1 isn't lean mate, it's VERY rich! ideally you want mid 12's I'd think. I'd imagine something will be a miss somewhere. more than likely a boost leak. it'll be seeing the air coming in through the MAF, and fuelling for it accordingly, so when some of the air escapes, you end up with too much fuel.
    Have you checked the fuel trims?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    AEM Uego.
    i haven't got vag-com outside work
    might take a look for vac/boost leaks over xmas time off. see if i can find anything
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    How easy is the fpr to change? Any linkys people
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    pull the U clip out (don't know the proper name for it) then just prise it out. easy 2 min job
    RIP S3dave
    May 2004
    nr Glos
    7,166
    14.7 AFR Lambda 1
    Leaner is higher than 14.7
    richer is lower than 14.7
    Usual zone to aim for is in the 12's under boost, not 11's or 10's
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    does vag shows any faults for a faulty fpr? my car is running lean (14's all the time, boost or no boost)
    are there any upgrades or just replace with oem?
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Quote Originally Posted by Chlippo View Post
    There is no fault code for the FPR as its not electrical and therefore not tied into a module of any kind that can monitor its state... however there are tell tale signs which can be logged through VCDS and of course a pressure gauge
    Should be mentioned that it is rare for an FPR to go faulty... only FPR related issues I have seen has been from BAM engine code S3's when bits of rubber from the fuel pipes have collected in the fuel bowl around the FPR blocking it off but that gives different symptoms... in situations like this is is more likely the fuel pump thats at fault as it gets tired and cannot deliver the required fuel pressure under boost... as boost goes up so does the FPR's rating (3bar + boost pressure) and the harder the pump has to work... a tired pump won't be able to keep up and therefore goes lean under boost...
    The easiest way to diagnose fuel pressure issues is to just fit a fuel pressure gauge in the fuel line and see if the pressure rises at the same rate as boost... should be around 3 bar (on a 3 bar FPR) on idle rising to whatever your peak boost is (if 1.2bar then you will see around 4.2bar)... if you don't see that then its likely the pump is the culprit...
    On a wideband ECU (AMK/BAM/AUM) you can check blocks 001 and 031 and you will see lambda adjust in 001 go mental trying to add fuel and the actual lambda in block 031 start to go into leaner figures despite the request being whatever it is... checking block 032 will show if there is a large positive figure in the long term fuel trim too
    Chilippo... in your case (as I remember you posting about this before) having 14's across the board sounds more like thats what the map is asking for... logging block 031 in VCDS will show you this... 14's sounds like std fuelling and IIRC you have had yours mapped and not logged... logging block 031 will show you what your fuellign is doing... if the request is 14's and the actual is 14's then the only problem you have is your remap... if the request is mid 12's and the actual is 14's then maybe you have an issue
    <tuffty
    RIP S3dave
    May 2004
    nr Glos
    7,166
    as Previously said.....
    log block 031 and confirm what the MAP Is REQUESTING
    If dimsport, then their "lambda" map aint correct.... and does diddly squat
    www.badger5.biz
    bill@badger5.co.uk
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    Thanks tuffty. Bill proposed to log those (and i will) but for my own curiosity and knowledge your explanation was needed.
    I will get a proper vag next time i work on the car.
    Audi S3 AMK
  1. Running lean??
    By AudiiduA in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2011, 20:22
  2. Running lean?
    By A4-Newboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2010, 11:22
  3. Running lean!!!
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2009, 18:12
  4. running lean i think
    By slight_problem in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 12:01
  5. Fuel System to Lean - what is the cause?
    By IanL-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2005, 00:31
