Chris NottEM Tuning
Results 1 to 11 of 11
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    A3 gearbox changes
    I have an a3 1.8 turbo sport Quattro. Just wondering if anyone knows if there are any 6 speed gearboxes that will fit my car.
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Do you mean are there any forsale? Id suggest contacting an ebay seller breaking a quattro A3. And if you mean what code gear box then contanct a guy called reesey on here and he may have one forsale.
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    No I just ment like my a3 is a 5 speed so would I b able to stick a 6 speed box of another a3 or s3 onto my engine, cheers.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,069
    Yes, you could fit a 6 speed box onto yours, although I dont really see what you'd be gaining to be honest1st gear seems to be too short on te 6 speed, and 6th is about the same as 5th on a 5 speed
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    Oh rite got ya mate cheers. Just seems like the gear ratios are to short on the 5 speed. Thought the ratios would b higher on a 6 speed. I see what u mean thow so cheers.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,069
    too short? the 6 speed is just the same in terms of top speed, I think 5th on the 5 and 6th on the 6 are pretty much the same gear.
    the 1.8T doesn't need 6 speed in my opinion, it has a decent spread of torque to haul you along fine in any gear. Any time I've driven 6 speed 1.8T cars I just get annoyed at how often you need to change gear! 1st is also useless as it's too short, and the rest are just closer together.
    beachbuggy's Avatar
    Surrey
    1,727
    5 speed boxes you'll hit 60 in 2nd where as the 6 speed you need to change up before you hit 60 and the limiter.
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    Got ya so better of sticking with a 5 speed then. Cheers lads.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,069
    Quote Originally Posted by beachbuggy View Post
    Believe it or not, you can actually get bloody close to 80 in 2nd on a 5 speed box! I'm fairly sure a rev limit of 7800rpm (hybrid or BT setup) would see you 80 in 2nd on a 5 speed.
    Not that top speeds in gear count, I just don't feel the turbo delivery of the 1.8T warrants a 6 speed, something like hondas K20 that you need to keep on the boil yes, but a torquey turbo motor not so much
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    I hate the 6 speed box in the S3 personally. I think it has been badly designed and as for ratios leaves a lot to be desired. I can now hit 60+ in 2nd, but that's only due to a raised rev limiter.
    I would love a 5 speed box and the 4 wheel drive
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    Got ya mate. Settled my problem. I thought a six speed would have been better all round but by the sounds of things a six speed box would be worse. Think I'll stick with my 5 speed then. Cheers lads
  1. 01E 6speed gearbox oil different from 02M 6 speed gearbox oil ?
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd October 2009, 15:44
  2. Replies: 0
    Last Post: 19th June 2007, 16:44
  3. Leaking gearbox oil 2.5TDI with a manual 6 speed gearbox.
    By Joni_s in forum A4/S4 forum(B5 Chassis)
  4. What Gearbox? How to identify Gearbox?
    By Dave_Bayern in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2007, 10:30
  5. Replies: 2
    Last Post: 28th February 2005, 20:59
