Volks AutosSky Insurance
Results 1 to 13 of 13
    Jun 2004
    Surrey
    595
    AndyMac stealth sub upgrade
    I ordered the stealth sub and amplifier from AndyMac and a couple of days later a complete kit arrived. With some comprehensive instructions, amp setup and wiring clearly labelled, this is going to be Childs play.
    Well it took a bit longer than I thought. I did almost all of the work yesterday afternoon apart from the rear speak panel. A couple of clips snapped off so I was waiting for the glue to go off properly. There is quite a bit off work involved and having the right tools to hand is a must but the results are well worth it.
    I know this should go in the ICE section but it is more relevant to the A3/S3 forum as it is a great stealth upgrade and you don't lose any space in the boot. If you haven't got one yet, go get one you won't regret it.
    A big thank you to Andy!
    Steve.
    [image]http://www.audi-sport.net/gallery/showphoto.php?photo=890[/image]
    Jun 2004
    Surrey
    595
    Re: AndyMac stealth sub upgrade
    Nov 2004
    cambridge
    75
    So how does it sound? Much better than OEM?
    What did that set you back?
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Looks sweet dude, just curiouse, does it rattle much cause the subs in there ?
    Jun 2004
    Surrey
    595
    Ask AndyMac for the prices as it depends on what you want and whether you have Bose or not.
    Jun 2004
    Surrey
    595
    I used some dynamat under the sub and on the rear wing and then put the original foam back on top so it doesn't rattle at all.
    Jan 2005
    60
    I totally agree.
    The AndyMac ss upgrade is the second best upgrade on my car (and the best is the engine upgrade :-)
    Looks like you got loads of space for your sub - I trust you that is not what I've got with the Navi-cd reader, mobile phone and parking sensor stash all mounted above the original sub (but I made it in the end)
    I used the same dynamat technic as you did, and mine dosen't rattle either.
    regards
    100% happy customer
    hopper's Avatar
    Jan 2005
    stoke-on-trent
    122
    [ QUOTE ]
    I totally agree.
    [/ QUOTE ]
    was considering 1 of these myself cuz i like the fact it aint on show but ended up fitting my sub and amp cuz its was just sitting about. i only have a kenwood sub and amp but it does sound well but was considering how the andymac sub compares to a normal sub and amp setup
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,563
    [ QUOTE ]
    [ QUOTE ]
    I totally agree.
    [/ QUOTE ]
    [/ QUOTE ]
    I have the Andymac upgrade aswell, it's a huge improvement over the standard Bose sub, and compliments the Bose fit speakers, but it's also not quite a seperate amp a sub setup imo.
    imported_Nigma
    Does the sub cause any problems being under the CD changer?.. I would have imagned it to cause the CD to jump and impose some knocks to the mechnicals of the changer?
    Jun 2003
    World of my own
    9,813
    Yes, agree with jojo, it can't compete with a proper sub, the thing is tiny for godsake. It really sits between the standard sub and a proper sub. At lower volumes I actually prefer it to my 10" ported Alpine in my A4, it has more punch with no overwhelming low bass which can drown out everything else (and means you're constantly adjusting the levels), but obviously at very high volumes it runs out of steam and you have to back off the Bass a bit.
    If you've never had a proper sub then it will knock your socks off, but if you're used to a proper sub then it is most definately a step down.
    Thanks for the positive review Steve, can't believe you got it all fitted the same day it was delivered! Nice work.
    Cheers, Andy
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,563
    [ QUOTE ]
    [/ QUOTE ]
    Using the factory CD changer, there's no way to bolt it down, so I used 2 layers of double sided pads. I've not heard it jump once and I'm running 19" wheels aswell [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Dec 2004
    North London
    209
    is it some sort of audi wiring going into this sub or are they standard rca's? do you run it off the head unit amp or has audi got one of them behind it?
    Sorry for the questions but i never get round to pulling it all out to have a good look
