Badger5Monster Motorsport
Results 1 to 7 of 7
    Aug 2010
    bradford
    1,252
    Something weird after fitting Milltek cat back
    Well before I fit my Milltek cat back I had standered exhaust and tested what the cat could do on my liquid gauge bhp, g's, temp, boost and then after fitting my Milltek resonated cat back I did it again and my boost went from 12 psi to 15 psi is this normal or something wrong weird to me and gained about 10 bhp as well if not more as I did not open it up as much pleased with it sounds great too
    I want more sound so should I take resonated out
    Tar
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    S3 Paul's Avatar
    Oct 2006
    2,764
    Hi,
    The gains are probably down to the turbo not being as restricted ,
    You can buy an un resinated section so basicaly its just the cats then a pipe to the back box,
    Sounds better unresinated in my opinion
    Noggy Blue 2001 S3
    Aug 2010
    bradford
    1,252
    Cheers Paul do Milltek do the dypass pipe or custom made one I allready have a decat so no cats there do u no why the boost has creped up
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would guess that the actuator and map are set up for how the car was...
    The less restrictive exhaust will be allowing waste gas to flow easier/ faster through the exhaust, ( guess work )
    Miltek do sell the unresinated section as thats what i bought. Wasnt cheap mind, about £150 i think
    Noggy Blue 2001 S3
    Aug 2010
    bradford
    1,252
    Oooow steap lol for that little bit ha just make custom for 30 lol well I'm running standered map as my map was crap so tuck it off
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    These cars have a boost sensor, and the ECU works to a target pressure. I wouldnt have expected to see any real increase in boost pressure before/after. Perhaps a little overshoot now due to the decreased restriction but the held level should be the same.
    TD5 Land Rover Defender build
    Aug 2010
    bradford
    1,252
    I don't get it it's now constantly at 15 psi when I open it up before was 12 and my boost gauge says 10
  1. Milltek connecting pipe - cat back to oem cat?
    By dickys3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2011, 16:42
  2. Fitting a 3" Cat back stainless exhaust to a standard Cat
    By g60leigh in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2010, 16:14
  3. Milltek Cat-Back
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2009, 14:25
  4. Milltek cat back
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2006, 22:08
