Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Apr 2010
    South Cheshire
    157
    Climate Control Unit - Turn Air Con off? HI/LO display?
    Merry christmas to all, not sure if it is snowing for any of you guys too?
    Just wondered if anyone knew whether you can manually turn the Air Con off but still use blowers/fans?
    I have seen HI and LO displayed on pics but not sure what this means?
    I have also witnessed Sandip changing settings on the Climate Control panel to show Engine Coolant Temp on the Climate Control display and have found the instructions for that so will be having a go myself!
    Chugger
    North Devon
    2,716
    Press the econ button!
    57 A3 2.0 TDI Sportback (140)
    Apr 2010
    South Cheshire
    157
    Quote Originally Posted by sportstractor View Post
    Is that it really? I have a few times but wasn't sure. Haven't got the manual at my place at the mo
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    It won't run once the frost warning symbol appears in the DIS anyway... 5deg or less and the aircon compressor turns off automatically...
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    On our avant we leave it on ECON most of the time anyway. If i need AC then i'll turn it on. Seems completely stupid that by default it runs the AC compressor all the time, even if its cold and trying to warm the car up!
    TD5 Land Rover Defender build
    Chugger
    North Devon
    2,716
    Quote Originally Posted by Poke13 View Post
    Yes econ obviously means economy. Just stops the compressor from running. Didn't realise that it stopped below 5degrees though. I always leave mine on ECON mode to help save fuel.
    Chugger
    North Devon
    2,716
    True, it should be better.
    Did they ever fit auxiliary heating on a3/s3?
    Apr 2010
    South Cheshire
    157
    Well the ECON seems to be working a treat but I have had no luck fiddling with the panel to show engine coolant temps/speed etc.
    Anyone else had any look with this? It must be possible as Sandip did it in my car.
    "Stick a V8 in it!"
    14,905
    Hold recirc and press the up arrow, the display will change to 1c. you can then use temp +/- controls to select which channel you'd like to view, 49c is coolant temp for instance, then press recirc to display the value.
    Apr 2010
    South Cheshire
    157
    Thanks for that aragorn!! I will be giving that a go!
  1. climate control air con
    By gaz4410 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2011, 19:12
  2. Air con- Climate control
    By MrBlack88 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th December 2010, 11:23
  3. Air Con/Climate control FAQs
    By Staz in forum Air Conditioning
    Last Post: 26th June 2008, 19:58
  4. Air Con/Climate Control Problem
    By shippy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th May 2006, 17:50
  5. climate control unit display bulb
    By spunn in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2004, 21:11
Tags for this Thread
