EM TuningAH Fabrications
Page 5 of 7 FirstFirst 1234567 LastLast
Results 161 to 200 of 278
Like Tree1Likes
Thread: 2.0 TFSI Coil Packs on a 1.8T
  1. #161
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Thought that was what they meant..
    How do yuo open the gap? and how do you measure the gap once opened? its not a fiddly bending trial and error job isit?
    Cars:
    Now: Audi TT Project car but looking for An S3 Project.
    Past: Audi A5 3.0 V6 TDI 300BHP 481 lbft
    Past: Audi S3 MTM 345BHP
  3. #162
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Quote Originally Posted by RyanS3MTM View Post
    Have a look online mate, loads of detail there:
    Google
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #163
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Quote Originally Posted by Westy View Post
    They are talking about the gap of the spark plug. The plugs we run have a gap of 0.8mm where the TFSIs have a 1mm gap. The larger the gap the bigger the spark.
    The TFSI coils are made stronger then the 1.8T coils to run with 1mm gapped plugs. The general idea is that the larger the gap, the larger the spark, the better the combustion, giving more power.
    Tests are inconclusive with regards power gains... don't do the TFSI swap if you expect more power... its like a lot of mods for forced induction engines... these are mods that make the best of what you have... like FMIC's and the like...
    You could argue that this allows you to run more boost reliably (without misfires) and thus you can attain more power but you won't get more power by just fitting them..
    I would advise sticking to 0.9mm plug gap tbh... 1mm seems big and not really needed considering these engines do ok most of the time on a 0.7mm gap and 20v fail packs...
    No point in making the car more unreliable that it needs to be...
    <tuffty/>
  5. #164
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    He has got a big turbo on his and a print out of 345bhp (dyno lottery i know) but from experiance that kit runs very hot so i reckon 7's will do the job as they reconmend possibly 7's on remapped
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  6. #165
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Quote Originally Posted by StaceyS3 View Post
    Ah... ok... yeah... 7's then
    <tuffty/>
  7. #166
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    When you say 7s do you mean?
    as seen in RS4s?
    Cars:
  8. #167
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    PFR7Q, PFR7W-TG
    as seen in RS4s?
    I was referring to BKR7EIX (iridium) or PFR7Q (platinum)... dunno if these are used in the RS4 but makes sense that they are..
    <tuffty/>
  9. #168
    RIP S3dave
    May 2004
    nr Glos
    7,139
    By cooler ones you mean the 6's or 8's? I use 8's as I have a big turbo conversion and best part of 400hp... you only need 6's (which are hotter in the plug heat scale)
    Gap wise there is discussion of opening the gaps to 1mm using the TFSI packs but tbh the std gap is 0.85mm so I have them set to 0.9mm which I personally think is a happy medium... running larger gaps on 20v coil packs reduced their life expectancy as they have to work harder to make the gap... 0.9mm works on mine and I have had no misfires even when running over 2bar of boost where the normal 20v's (the 3yr old ones I had) would have a hissy..
    <tuffty/>
    ryans is uber hot k26 mtm tubby tho tuffty
    egts will be high i think if anything like staceys
    colder.... 7's..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  10. #169
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    colder.... 7's..
    Yeah... seen that now lol
    Should have remembered from his user name LOL... DOH!!!
    <tuffty/>
  11. #170
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Thanks Guys, Think ill be getting Spark Plugs and coils mid next week and fitting, and space the Spark plug 0.9mm-0.95mm accordingly..
    Do I buy a cheaper spark plug gap tool or does anyone have an alternative method? or one i can use?
    Cars:
  12. #171
    Chugger
    North Devon
    2,716
    is there still intrest in fitting these coils to the 1.8t, as tests show that there isnt anymore power to be had, but surely its worth it if they are smoother, more reliable and help your engine produce a better MPG?
    Iv order some of the red TFSI coils which cost 24.50 + vat each from GSF and getting some of the adapters made up by a mate using cnc water jet equipment and hopefully getting them finished in polished alloy or powder coated. Would anybody else be potentially intrested in a set as im getting a few made for friends and could get a few more done, this isnt a group buy btw, just gauging intrest.
    57 A3 2.0 TDI Sportback (140)
  13. #172
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Sportstractor are you joking on how much you paid? Awesome are doing a full set of red at the minute for £75ish delivered!
  14. #173
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    They won't give more power only the potential to run more boost really... and that is dependant on the turbo you use etc too... personally I think they are a better coil pack than the 20v one and therefore you are no worse off using them... if you are in the market for coil packs then there is no real reason not to consider them...
    Personally I think there is better part throttle response and idle using TFSI coils over 20v coils... mpg wise its difficult to say tbh as the car doesn't get out much and its current configuration means that when it does it kinda gets abused lol...
    <tuffty/>
  15. #174
    Chugger
    North Devon
    2,716
    YOU LEGEND, you just saved me £40 or so, i thought that was pretty reasonable considering what i had to pay for my 1.8t coils
    with the money iv saved iv also gone for a new coil pack loom
    <tuffty/>
    Not really needing them, but when i read that they were smoother and more reliable i thought i had to have, and hopefully il get some money back from selling my 6 month old 1.8t coils.
    If it gives me smoother idle and part throttle, il be happy. As the 1.8t and a bit rough compared to other engines iv driven.
    When they turn up il get some adapters made not paying £70 for a set from INA
  16. #175
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Happy to save anyone some dollar .
    I need to order some tonight.
  17. #176
    Westy's Avatar
    Dec 2008
    17,264
    I've got 10 1.8t coils that I need to sell!
    I've also noticed better idle/part throttle too, and I'll definitely be using TFSI coils in future.
    S3 Build Thread
  18. #177
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Westy: bolt downs or push ins?
    TD5 Land Rover Defender build
  19. #178
    Westy's Avatar
    Dec 2008
    17,264
    All push ins i'm afraid mate, they no good for you?
    S3 Build Thread
  20. #179
    "Stick a V8 in it!"
    15,317
    Nah i'd need bolt in ones.
  21. #180
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Aragon why you after bolt downs? My will be for sale when my tfsi ones come from awesome.
  22. #181
    "Stick a V8 in it!"
    15,317
    It'd be a cheap ICM delete using those rather than going to the expense of TFSI ones.
  23. #182
    Jan 2012
    Langdon Hills/Southend
    41
    Looks like I'll be doing this mod in the near future as my coil pack is on it's way out anything above 3k at full boost I get the occasional miss sometimes pretty annoying,
    I need bolt downs too unsure where to source them from though as well as spark plugs.
  24. #183
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    I've still got 3 bolt downs and 1 push down. Might order the reds tonight but I need a push down rocker cover!!!
  25. #184
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Just a heads up as well guys, ive just been on the phone to awesome and the tfsi coils arnt in stock yet, they said itll be sometime this month, but when they dont know.
  26. #185
    Chugger
    North Devon
    2,716
    Ha I just got off the phone to them aswell, apparently there on a shipment waiting to be cleared by customs... Ghey. Anybody reckon it's worth having them when I go in for mapping on Friday, or wouldn't it make any difference fitting afterward?
  27. #186
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Quote Originally Posted by sportstractor View Post
    Won't make any diff to the mapping tbh...
    <tuffty/>
  28. #187
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Have ordered some from awsome but like danny said not sure when tey will turn up??
  29. #188
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I'm tempted to do this too. I'll wait till they're in stock before ordering, any way I could probably do with upgrading my wiring loom before putting fancy new coilpacks on ...
    I noticed they do a replacement coil pack loom. Neither (according to their blurb) seem to be applicable to my S3 (AMK) unless A3-8L implies S3-8L too????
    Awesome - Coilpack Wiring Loom Replacement for oil level sensor cars
    Will I have to cut the existing loom off and crimp a connector block in for the new loom?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  30. #189
    Chugger
    North Devon
    2,716
    AMK has level sensor
  31. #190
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Yeah I know it has the sensor.
    I just phoned Awesome and the guy on the phone said they don't do any replacement coilpack looms which will work with an S3 (K04)
    Liam
  32. #191
    Chugger
    North Devon
    2,716
    Hmm, I hope that's not the case cause iv ordered the one with the level sensor, I'm sure it'l work, just needs some wiring which I'm not afraid of, maybe tuffty can confirm
  33. #192
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I hope so too. TPS have 1J0 971 658 M as a live part number on their system so I've ordered one. But they said it's not listed for any particular vehicle. £25 + VAT.
    Liam
  34. #193
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    The replacement coil pack wiring loom is a generic VAG loom... the coil pack loom can be used by splicing it in... I was planning on getting the cheaper one (without the sensor wiring) and just splicing in the coil pack wiring rather than run it all the way back to the ECU... you don't need all the other stuff really as its only really the coil pack stuff thats buggered...
    <tuffty/>
  35. #194
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,453
    The loom i got from Awesome was one from there website with the oil level sensor
    VAG part number 1J0 971 658 M
    I just cut into the old and new loom and made it fit
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  36. #195
    Chugger
    North Devon
    2,716
    Cool, that's what I was hoping for. My wiring is shock, I'm surprised it's not causing problems
  37. #196
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,381
    Sorry if this has been covered before but I'm reading on my mobile and keep going backwards and forwards through the post.
    If fitting the tfsi coil packs to an amk do I need to replace the loom if mine is in good order.
    Thanks.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
  38. #197
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by g60leigh View Post
    Thanks.
    No you don't.
    I have an AMK - but my wiring it pretty knackered from the heat/age. I don't particularly have any noticeable problems but when I saw the condition of my wiring I was surprised that I don't have more problems.
    I'm going to spend my money on making sure my wiring is tip top before I throw money at the new coil packs.
    That's just my two pence.
    Liam
  39. #198
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I'd be up for a set. I'm back in the UK in a week or so for two weeks. You planning on making them soon?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  40. #199
    Chugger
    North Devon
    2,716
    Hopefully will be done in a couple weeks, going to get some spares done as its a lot cheaper to make more while the tooling is setup. Just waiting for coils to turn up for dimensions
  41. #200
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    What sort of price will the adaptors be?
  1. A3 Coil packs
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2012, 20:45
  2. Cheaper coil packs and better running (MarkIV TFSI coil pack)
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 13:59
  3. Coil packs
    By rusty s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2009, 10:13
  4. What are the best coil packs?
    By CycleSi in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2008, 00:00
  5. Coil Packs?? Help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2004, 21:19
