ben4866
Morning all, wondering if anyone can help.
Ive got an A3 AGU 1.8t which won't start. Inspected the spark plugs and cylinders 1 and 2 were dripping with oil as well as the ends of the coil packs, the plugs litterally covered in oil (cylinder 1 starting from timing belt end). No3 only had oil around the spark plug seating washer and end of the coil, no4 was totally clean.
Basically what happened is I got into the car the other morning, fired it up and then it ran for a few seconds and then cut out. It wouldn't fire again after that. Up until that morning the car had been running great with no signs of anything deteriating.
Also the car was parked up previous to this for 10 days without being started. Would it be possible for the valve cover to have leaked and filled the plug chambers ? Only thinking this because the coil pack ends are covered in oil ?
Now that I think about it more the spark plug socket I used was covered in oil as though it had been submerged in a pool of oil. Is it likely that the valve cover gasket had leaked, created a pool of oil above the plugs and when i slackened the plugs the oil ran down the threads and covered the plugs ? And the reason the car wouldn't run was because of coil packs wet with oil ?
Can anybody shed any light on what may have gone wrong ?
Any help greatly appreciated.
Regards,
Ben.
Regards,
Ben.
