Chris NottMonster Motorsport
    S3 Paul's Avatar
    Oct 2006
    2,764
    Please help security locking needed if possible ( vag com?)
    My other half and our young daughter have been out in either of the two dailys ( S3 and Bora tdi ) and had some freak try and open the door at the lights,
    The mrs is understandably shaken and to be honest so am i,
    Am i right in thinking with Vag Com i can turn on a system that will automaticaly lock the doors once the car goes above a set speed?
    This may i think reasure her and put me at ease.
    Is this possible? I tried to look it up but couldnt find a clear answer or how too.
    Noggy Blue 2001 S3
    beachbuggy's Avatar
    Surrey
    1,745
    It is certainly possibly in the MK4 golf as I did this exact thing on my wife's car. It automatically locks the doors when you go over 10mph.
    It's done with Vagcom, i'll have a look for you to see which setting it is.
    27,111
    Check in 35 Central Locking.
    This is from a mk4 golf, may share the same info:
    VW Golf (1J) Central Locking (Generation 2) - Ross-Tech Wiki
    beachbuggy's Avatar
    Surrey
    1,745
    This is what I used for the Golf assume it'll be the same for the S3
    [Select]
    [46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
    So, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
    Lock/Unlock Horn/Flash:
    [Select]
    [Adaptation - 10]
    Channel (03..08)
    Adaptation Value (1 = on, 0 = off)
    [Save]
    Channel 03 Auto Lock
    <font color="red">Channel 04 Auto Unlock </font>
    Channel 05 Unlock, horn sounds
    Channel 06 Lock, horn sounds
    Channel 07 Unlock, turn signals flash
    Channel 08 Lock, turn signals flash
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by S3 Paul View Post
    I'm sure a few s3 owners on here have done it:
    The easiest route is to download basecode as it will calculate the code you need to enter into vagcom.
    Then this is what i had to do to do mine:
    1. Click “Control Module –35”
    2. Click “Recode – 07”
    3. Write down the numbers in the “Software Coding” box and keep it in a safe place
    4. now open up “”Basecode” (that you downloaded) and put the numbers you wrote down into the box that says “Start Base Code”
    As you tick the boxes of what you want to add (“Auto doors above 15mph” in your case) you'll see your new code in the “New Base Code” box .
    5 Now go back to vagcom and enter these numbers into the box where you wrote the numbers down and click “do it”
    That it your all done
    EDIT: Heres a link to Basecode: http://www.thewellings.co.uk/downloads/basecode.zip
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Hey Paul, sorry to hear this, hope they are both ok..
    It is possible, I had it done on my car as soon as I got it as the missus does drive it from time to time, it auto locks as soon as it hits 10mph.
    I have also got total closure enabled and selective unlocking too - thought this was useful, as no point having all the doors and boot unlocked, if its only one person in the car.
    Sorry I cant help with codes etc, but im pretty sure its the same as the Golf Mk4 to get this done.
    Let us know how you get on.
    Nilz
  1. HOW DO I TURN OFF SECURITY CENTRAL LOCKING
    By BUSTER A4 MISANO in forum General Technical / How To
    Last Post: 5th February 2012, 13:40
  2. security access codes needed
    By tdi-man in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th March 2011, 08:44
  3. vag com security access code
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2011, 10:32
  4. Auto Door Locking via Vag com
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2009, 18:56
  5. vag-com locking/unlocking
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th March 2007, 03:28
