Volks AutosSky Insurance
Results 1 to 10 of 10
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    8L empty fuel tank- the gauge lies!!
    Hi team,
    I'm sure this has been covered before but I thought I'd ask the idiot's question;
    Is fuel-gauge sender failure a common issue?
    Last night my fuel light came on so I put in a £10'er. Then it came on again and so I put in a £10'er, then it came on again. Average mpg as shown by DIS at the moment is 38>41 mpg and the gauge shows the tank as empty also.
    I can't see a leak underneath at this point- or smell one.
    What's involved in a sender swap? Do I have to recalibrate the system or does it just "work" with a new sender? How much hassle is it and does anybody have a parts cost...?
    incidentally- I now drive a TDI quattro...
    (don't want much from this thread do I??!!!)
    Thanks in advance...
    JimP
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    I've just thought of something else;
    somebody told me that restarting a TDI after depressurising the fuel system was a major hassle- does anybody know is that true?
    JimP
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    My S3 did this once. Just went for a bit of a 'spirited drive' round some twisty roads and the sender freed up. Been ok ever since.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Chugger
    North Devon
    2,716
    Quote Originally Posted by jcs356 View Post
    Never had this but often get it on my vivaro van, it does free up though. If you run it right down £10 would bearly get it off the reserve light though, it's only 7ltrs of fuel. Isn't a good idea to let a diesel run out, some have pumps in them to help you prime them if you do, some are a right game from what iv been told
    57 A3 2.0 TDI Sportback (140)
    Aug 2007
    199
    I had a similar issue (irregular fuel readings) - I just filled the tank up with fuel with as much as it would take and the problem went away. So far (about a year) I have not had the issue return.
    got an S3 8L: living the dream
    Mar 2010
    Kent
    173
    my gauge on the s3 lied to me once.....the tank after i changed the fuel filter........said i had 5miles left as the engine conked out on the motorway!
    does the ecu need to relearn the amount of fuel in the tank after changing the fuel filter (thus losing fuel)???
    2002 S3 8L AMK
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by jimmp View Post
    I changed my diesel filter and turned the ignition on and off to accessory mode as it primes the fuel pump. Did it about 10 times and then start normally, spluttered slightly then was fine.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Jul 2011
    middlesbrough
    112
    easy enough job just pull back seats out and undo the cover over the "man hole" into the tank then unscrew the sender unit out and move it up and down a bit or clean the tracks with some brake cleaner.. worked for me before on my golf....
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    So this is happening on a diesel? Iv had 0 miles read after only putting £6 of petrol in when i forgot my wallet, how many miles where you getting inbetween the £10 you had put in?
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    hey-
    thanks everybody for your feedback. I was thinking that being diesel question, there would be no response, but I've been proved wrong!
    thanks for your help
    as it happens; the gauge rolled off from 60 miles left to 0 miles left in 30 seconds. After a refill it never moved from 0.
    I checked under the car as much as I could for a leak but there wasn't one and last night it had fixed itself.
    More fuel from now on
    everyone
    JimP
  1. Petrol Gauge shows 1/4 tank when empty..help
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2011, 01:11
  2. 2006 A6 Fuel gauge reading empty.... (2.7 tdi)
    By A6Ian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th May 2010, 10:39
  3. Fuel Gauge always showing half a tank more than I have
    By boson in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2009, 00:00
  4. Had a flat battery now fuel gauge reads empty.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2009, 19:34
  5. fuel gauge telling lies !
    By bigdavie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th March 2008, 16:18
