Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
    Oct 2011
    Edinburgh
    144
    Question Audi A3 1.8T (8l AUM Engine): Strange noise - grinding/rubbing noise..
    I've noticed over the last 2 days that I have a strange grinding/rubbing noise coming from my car - I've done some searching on here and Google and can't seem to find any suggestions as to what it might be - the symptoms are below:
    * only happens around 1200-1250 rpm
    * happens when engine is hot or cold
    * happens when engine is stationary or driving
    * pressing clutch has no difference
    Given the above I'm fairly certain it won't be any of the following:
    * cv joint
    * power steering rack
    * release bearing
    * flywheel
    I'm pretty stumped with this one? - I only noticed it after having my new tyres fitted - but can't see how that would have been anything other than coincidental.
    Does anyone have any ideas or suggestions??
    * 2013 BMW 116d M Sport: current
    * 2002 Audi A3 1.8T Sport (8L): current
    * 2003 Mercedes Benz C200K Avantgarde SE (W203): current
    * 1998 BMW Z3 2.8 Roadster (E36/7): now sold
    * 1998 BMW 316i Compact (E36): now crushed!!
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Sounds like a nakerd cv to me or wheel bearing. Dont panic lol try jacking it up and spinning the wheel by hand to see if bearings are on way out and check for split cv.
    Oct 2011
    Edinburgh
    144
    Quote Originally Posted by camscockle20vT View Post
    thanks for the reply - it happens when the car is stationary though?.. that would probably rule out a CV joint or wheel bearing??
    Nov 2010
    1,673
    Oh stationary aswell :/??? Il have a think lol
    Oct 2011
    Edinburgh
    144
    thanks!
    Nov 2010
    1,673
    Could it just be somthing vibrating off somthing else?
    Oct 2011
    Edinburgh
    144
    possibly.. i'll need to try and have a proper root around in daylight!.. pretty stumped with it at the minute though and annoyed because i don't know what it is! LOL! - especially with it only happening over a short RPM range (that kind of suggest that it is a vibration of some sort - but why has it just started doing it now!! grrr... annoying!!)..
    thanks for the replies! - I'll update with an outcome if I get to the bottom of it.. all other suggestions are still welcome at the moment though! :D
    Nov 2010
    1,673
    Lol they can be strange cars dude, have you modified the car in any way?
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    there has been a guy on here (cant remember his name) who had a simular rattle around that rpm range, his rattle turned out to be the cam belt tensioner damper.
    ill see if i can find you his thread
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    here you go
    A very lucky escape
    may not be your problem but it may be worth a check
    1.8T SPORT AUM
    Progression Thread
    Oct 2011
    Edinburgh
    144
    Thumbs up
    thanks for all the replies!!
    it did end up being a heat shield!! - now sorted FOC!! (phew!)... :D
    the first thing I done when I got the car was to get the timing belt, tensioners and water pump replaced! :D
  1. Replies: 0
    Last Post: 27th August 2010, 18:31
  2. Problem number 1 of ownership! Grinding noise and knocking noise help!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 09:17
  3. Too much of wind noise in cabin and grinding noise on start up
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2010, 08:49
  4. Strange grinding/vibrating noise from rear wheels when turning!!??
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2010, 11:38
  5. rubbing/grinding noise
    By mintie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 18:56
