Chris NottMonster Motorsport
Results 1 to 8 of 8
Thread: Dogbone problem
    *Rich*'s Avatar
    Professional
    Jul 2006
    West Yorkshire
    100
    Exclamation Dogbone problem
    Hi all,
    i know this has been covered before, but.......whilst trying to remove my dogbone mount today, i managed to snap one of the bolts that goes to the subframe, it snapped clean at the head of the bolt so the dogbone has the raminder of the bolt and then the rest in the subframe.
    Now, is the part of the dogbone where the bolt goes in threaded or not, i don't want to try the other bolt, until i know. I was gonna get some heat on the bolt if it's not threaded, and molegrip it out that way.
    Any other tips? Please, need to get this done asap.
    I'll be getting new bolts for it, so when fitting them should i apply anything to the threads first, i'm led to believe these are stretch bolts going into the subframe.
    Cheers, Rich.
    Audi S3 2001 AMK Gone!
    parts for sale in here.... http://www.audi-sport.net/vb/sale-wa...ml#post1544516
    Aug 2010
    30
    had the same problem. Wd 40'd other bolt left for 24 hrs ,got this one out.Then wiggled dog bone off,one stud left in subframe.Soaked it in wd 40 for about an hour,then unscrewed it with a pair of grips. replaced with new studs
    *Rich*'s Avatar
    Professional
    Jul 2006
    West Yorkshire
    100
    Cheers mate, so there is no thread inside the actual dogbone itself?
    Gonna order all four new studs tomorrow to replace them all.
    Aug 2010
    30
    no thread
    *Rich*'s Avatar
    Professional
    Jul 2006
    West Yorkshire
    100
    Ok, thanks mate.
    *Rich*'s Avatar
    Professional
    Jul 2006
    West Yorkshire
    100
    What a Ba****d these bolts were to get out, ended up using heat and impact just to free the dogbone from the bolts......once it came of, the bolts were only just past finger tight.
    Anyway, all new bolts fitted, and yellow bushes squeezed in, much better now, a little vibration, nothing i can't handle. So all is good.
    STEVE a31.8t sport FLYER's Avatar
    Apr 2009
    bristol,england
    29
    where can i buy new bolts from as ive had the same problem - i need all 4 for the dogbone mount. i bought a new mount from ths its the fr3 but came with no bolts - wish i bought the new mount from ecs they come with new bolts ....
    a31.8t sport flyer - aum engine from golf ann (180bhp), Sports down pipe and cat, full stainless exhaust, remap, forge 007p, cold side relocation kit, k'n panel filter, standard airbox with custom 3" cold feed, volt and boost gauges on dash, red custom floor mats
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    If its this bolt
    You are probably best going to Audi!
  1. Diesel dogbone
    By Buzzer in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 09:15
  2. Dogbone Bush
    By edition in forum DPM Performance
    Last Post: 17th February 2010, 13:58
  3. Dogbone Mount
    By neil20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2007, 17:42
  4. S3 Dogbone mount
    By Buster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2006, 19:05
  5. dogbone mount.
    By millsyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2006, 16:01
Tags for this Thread
