Badger5Monster Motorsport
Results 1 to 11 of 11
    Jun 2011
    116
    Car not starting, Help please guys.
    Hi folks,
    Driven upto the folks this weekend, just drove upto a mates there, no bother, everything completely fine.
    Come out the house and fire up the car, its turning over but refusing to start.
    Car has been completely fine, no sign anything was wrongetc etc.
    Has had 4 new coil packs and no warning lights on the dash.
    Any ideas guys?? Surprised it was fine one min / not starting the next
    Thanks in advance
    Chris
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Could be dodgy battery this time of year dude.
    Chugger
    North Devon
    2,716
    Fuel pump priming when you click the ignition?
    57 A3 2.0 TDI Sportback (140)
    Audakas's Avatar
    Mar 2011
    London Wembley
    91
    Well you would know if the battery died, well if fuel pump works deliver to injestors, plungs new starter motor spins the engine, it should start, have u cheked the timing belt or any fuse blown?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    you need to check to make sure your getting fuel and a spark first.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Sep 2010
    Devon
    756
    Don't want to be the angel of doom but had exactly the same thing happen to me 3 weeks ago, unfortunately it was the starter motor in my case.Car worked fine in the morning, started it in the afternoon and nothing, no warning. Check your earth points under the battery first but I'll put a pint on it being that, easy 45min job though and the motor came in around %100.......
    Jun 2011
    116
    Starter motor is turning nice and strong.
    Timing belt was done by a VAG specialist in July just passed.
    Usually I hear a ticking by my right foot I think it is?? In the cabin anyway, Not hearing that, and I can't hear the fuel pump priming.
    Is there a relay for the fuel pump? Or are the fuel pump's bad for going?
    I'm not that mechanically minded but think i'll see what I can tomorrow morning.
    Failing that, recovery and 140mile back to Edinburgh, argh
    Thanks for the help guys, really appreciate it, was just singing it's praise about how reliable it was lol.
    Chris
    Jun 2011
    116
    Just checked all the fuses on the drivers side door panel and the fuses on top of the battery, all OK.
    Where is the fuel pump relay? I'm sure when i usually turn the ignition on i hear a click, pump primes then i fire it up, not hearing the click or the pump prime now.
    Is this a cheap bit to replace? Think i'll just get it recovered to the garage tomorrow, let them sort it.
    Was just about to give my VAG made mate with a VR6 golf a shot and was telling him how reliable it had been lol
    Chris
    Chugger
    North Devon
    2,716
    I'm pretty sure the fuel pump relay is in the drivers foot well, although I couldn't tell you which one it is. An easier option may be to expose the fuel pump through the hatch under the rear seats, and test your getting voltage there. The pump should prime on 2nd stage ignition. I have read about fuel pumps failing.
    If you got breakdown cover I'd get them out to be honest, it's what you pay for.
    Jun 2011
    116
    It's breakdown through my insurance, imagine all they will do is just recover me, experience of them in the past is pretty useless, only just got rid of the AA too :S
    Sh*t luck tonight, my little brother just reversed into my car 10 minutes ago, raging doesn't even come close.
    Front bumper will need sprayed, golf ball indentation from his towbar :'(
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    hey Chris...
    what's the verdict? what's happened since?
    JimP
  1. S4 not starting. Please help guys...
    By S4DJB in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th August 2011, 22:30
  2. probs with starting the car
    By skinz in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2011, 01:58
  3. problem in starting my car
    By mkh1357 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st August 2010, 04:54
  4. Help!!! Car starting problem!!!
    By ant123456 in forum Volkswagen and other VAG
    Last Post: 17th April 2009, 23:00
  5. car not starting
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2008, 15:14
