EM TuningBadger5
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    cooling system malfunction
    code read : 17704 cooling system malfunction...
    where do i go from here?
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    i would say either the water temp sensor or the rad fan switch but most likely the first does the fan kick in
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    well its not shown to be hot enough for it tbh, when do the fans normally kick in 90?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    If you get any error codes, check them here: Category:Fault Codes - Ross-Tech Wiki
    17704/P1296/004758 - Error in Mapped Cooling System
    Possible Symptoms
    • Cold start issues
    Possible Causes
    • Coolant Temperature Sensor (G62) faulty
    • Coolant Thermostat faulty
    Possible Solutions
    • Check Coolant Temperature Sensor (G62)
    • Check Coolant Thermostat
    Special Notes
    • Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
      • Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
      • Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
      • Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    thanks westy you diamond
  1. Getting cr*p out of the cooling system....
    By niftyandy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2010, 15:40
  2. Cooling system
    Last Post: 20th February 2010, 11:48
  3. Bleeding 1.8T cooling system
    By Marcos M in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2009, 21:19
  4. Cooling system
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2006, 11:55
  5. Cooling system ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2006, 22:14
