Sky InsuranceVolks Autos
Results 1 to 11 of 11
Thread: top mounts
    Jul 2011
    teesside
    16
    top mounts
    How do, top mounts require changing and was going to whip them out myself sometime soon, just wondered if anyone else has done this and the complexity of the task, also was going to pick up some oem bits from the tps nearby, but wondered if anyone knew of some better parts to use!
    Many thanks
    Addy
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    Use Seat Leon Copra R top mounts. Fit new bearings too while they're off. Took Me 40 mins to do both sides, but that was on a 2 poster lift with air tools!
    2003-03 8L S3 Dolphin grey - Porsche 996 calipers - Mo-vit 325mm 2 piece front discs - 15mm spacers all round - Miltek resonated cat back - Genuine RS4's - Vredestein Sessanta's - Forge 007p - Forge TIP - JR cone filter - Poweflex diesel dog bone bush - AMD Remap - Blue Haldex controller - FK AK Coilovers - Seat Leon Cupra R top mounts - 8P S3 gear knob and gaitor - TT pedals - Neuspeed quick shift - LED number plate bulbs
    14.2 quarter @ 97 mph
    Power? 241 bhp with a boost leak, now fixed
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Not exhaustive but will give you an idea of what to expect...
    LCR top mount replacement
    Shouldn't take too long but strut top nuts can be a bugger without an impact gun/air tools... have done them out the front of the house using a socket with a bit on top to hold with a spanner and an allen key to stop the damper rod moving... pita but can be done...
    I also used a special tool to help spilt the hub enough to get the bottom of the strut out... would advise doing that before undoing the top..
    <tuffty/>
    Jul 2011
    teesside
    16
    Any idea what the part numbers for those Leon cupra r bits?
    Nov 2008
    154
    Pretty easy, no need to remove the strut completely
    I jacked up the car and removed the wheel, then used another jack to raise the wishbone and compress the strut, then tied the spring up with ratchet straps wihile compressed. Undo top fixings, yes it's tricky, use a spark plug socket with an allen key through the square drive hole, spark plug sockets have a hex on them to put a spanner on so you don't need to use a ratchet. Now lower the jack to drop the strut out of the bush. Pull out bush, replace (tight fit), reverse procedure.
    It's a quick guide but it's not that hard a job surprisingly.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Quote Originally Posted by addyboult View Post
    1ML 412 331 - Cupra R strut top mounts.
    1JO 412 249 - Bearings.
    Jul 2011
    teesside
    16
    Cheers for the help guys! Weather permitting ill have this done on Saturday!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If your on coileys its even easier, just drop the top nut and you can change the bush in situ ....
    May 2009
    Midlands
    197
    There you go Addy, told you there is a wealth of knowledge on this forum :-D
    Nov 2011
    Finland
    131
    Why to use Cupra R top mounts? Are those stiffer, cheaper or what?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by BuuBBa View Post
    Stiffer... 80 durometer vs 55 durometer according to an independant test...
    Makes them a little more expensive of course but generally a lot of the LCR bushes are uprated as std so makes them a nice alternative to poly bushes
    <tuffty/>
  1. Top Mounts
    By colinurquhart in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2010, 15:50
  2. Top mounts
    By s3 ryan in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 21:29
  3. Top Mounts
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2009, 21:27
  4. Top mounts??
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th June 2009, 13:42
  5. S3 Top Mounts
    By alijames in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2009, 14:58
