Hello all, anyone out there replaced their stock discs for the EBC turbo groove ones ? I replaced mine (all round) a couple of weeks back along with Red Stuff pads. Since then I've done about 250 miles. When braking I'm hearing quite a bit of noise from the pads (whoosh type noise, more of a hum on hard braking which actually sounds quite good) - I was assuming that this was because of the dimples and grooves - am I right ? Should I expect them to quieten down as they bed in or is this what you'd expect ?
I also hear a slight rubbing sound when travelling (without braking) - I'm guessing thats just the pad rubbing till its worn a bit - or do you think its been fitted badly ? Fraid I'm not one to mess with brakes myself so had someone else do it
I'm not normally too heavy on the brake pedal and have been wearing them in gently with the odd hard brake recently so maybe they're not bedded in yet. Many thanks for any advice.
