Y
Yohan87
I've been doing some research trying to find out what "normal" values are for these.
Somebody on ClubGTI suggested the following oil pressures for the 1.8T engine.
Cold Idle (approx 1400rpm): - 87.02 - 94.30psi / 6 - 6.5bar
Hot Idle (approx 720-760rpm): - 20.31psi / 1.4bar
Approx 1000rpm: - 26.11 - 29.01psi / 1.8 - 2.0bar
Approx 3000 - 4000rpm: - 58.02psi / 4bar
Approx 6000-6500rpm: - 87.02psi / 6bar
However I can't find what is classed as normal oil temperature. The measuring location in question would be the sump and I was thinking somewhere in the region between 90-120C?
