Sky InsuranceVolks Autos
Results 1 to 23 of 23
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    installing bluestooth car kit / taking dash apart??
    HI
    i installed a Nokia CK-1W bluetooth handsfree kit into a friends car at the weekend. It was a ford focus and it was really easy to fit.
    But looking at my S3.... which is put together about 20x better than the focus... it doesnt look like its gonna be anywhere near as easy.
    Has anyone done this job themselves?
    How does the interior come apart? drivers side door pilar and roof headlining to get the mic up to the centre infront of the interior light?? glove box?? tray under the steering column? where do people put the control box and where do they get an ignition live (the Head unit doesnt suply one)
    thanks for the answers in advance
    Nathan
    Nov 2004
    Hosrham, West Sussex
    390
    Re: installing bluestooth car kit / taking dash apart??
    [ QUOTE ]
    HI
    Nathan
    [/ QUOTE ]
    Fitted the exact same kit in mine .. was easy.
    Glove box:
    Remove end panel, remove various torx screws. Also screws underneath and inside glove box - pulls out easy. My control box sits behind it.
    A pillar:
    Screws on the pillar itself, just pulls off.
    Got my perm & switched live from the fuse box - just poked around until I found one and spliced from there.
    Adam
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    I've got the Sony Ericsson bluetooth kit in my car but I got mine professionally installed, so sorry, I can't help!
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    where did you put the bluetooth control box and did you use the aux speaker or wire into your headunit for the sound to come out of the front speakers?
    glove box sounds easy enough.
    a piller... did you go up the drivers or passenger side? and it just pulls off??
    did you put the mic in the middle infront of the light? was it easy to route the wire through the headlining?
    where did you put the button on your dash?
    thanks... was not worried about doing it in the focus atall but bit worried about pulling the s3 apart.
    ta
    Feb 2004
    Leeds, Leeds, Leeds
    69
    Jedi Knight,
    I have put the Nokia CK-1W kit in my S3. I actually bought a proper wiring harness that you simply plug between the HU. This takes care of all your power and the speakers.
    I fitted the box behind the glovebox with cable ties and ran the mic up the passenger side A pillar. I didn't even have to take any trim off, you can easily hide the cable between the trim and the rubber seal.
    I fitted the mic in the middle of the light by notching out a little v right at the front of the plastic panel.
    Once you take out the light assembly there is loads of room to run the cable, you can even get your arm between the lining and the roof.
    The button is located at the side of the ash tray so there is no wiring on show at all.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    cool.
    what happens if you get a call and the stereo is no on then?? does it turn it on for you?
    i didnt think that harness gave the ignition power supply.. i think you still have to get that yourself from the fuse box.
    where does the wire for the button come out then? do you have a pic?
    so the wire up the a piller sounds easy as long as it doesnt pop out now and again... but how did you get it from the a piller to the light?? across the front of the screen??
    any pics or more details would be apreciated.
    thanks
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    I have SE HCB-300 which was fitted for me
    you need a tele-mute lead from autoleads or similar for it to mute your head-unit
    i learnt that bose is difficult for you to get it running through and with standard concert/symphony etc. it only seemed to go thru the head unit in mono/ one speaker only which seemed pointless
    wud just use the loudspeaker that comes with your kit and the telemute
    run mic up the a-pillar (easily done) and stick control unit in tray under steering wheel with the loudspeaker
    can anyone else confirm that it will only go thru head-unit in mono ??? (i was [img]/ubbthreads/images/graemlins/swear.gif[/img] off when i was told this as it seems such a stupid oversight)
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    there is a setting in the symphony2 HU that allows you to change between left, right or both. i know that much.
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    I have only the concert HU and its not actually running telemute at moment as i managed to pull one of the wires out at weekend when fitting my icelink - another thing to look at on my list...
    Feb 2004
    Leeds, Leeds, Leeds
    69
    Not sure about what happens when you have the radio off, never switch mine off but i'll investigate that.
    The wiring harness does give ignition power, i didn't have to tap into anything else.
    To get the mic from the A pillar to the light, you can pull the headlining out enough to get the mic through, get your arm up through where the light is and you should be able to find it. I don't have any pics unfortunately from when i installed mine.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    H3MSY
    can you give me the link where you bought your harness?
    the place i looked at definately said that the HU didnt give an ignition live.
    Also what HU do you have? i have the Symphony2 HU
    how does the light come out? just a small screwdriver in the gap and lever it out?
    ta
    Oct 2003
    Channel Islands
    213
    Ignition live at the head unit is dependant on the year of the car. Around 2001/2002 (may have been at the facelift), ignition on was a signal through the CAN-BUS. On later vehicles you will have to break into the fusebox switched live. Do a search in the ice forum, as AndyMac did a great tutorial on how to do it.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    i understand... and i found that post you mentioned
    http://tinyurl.com/5hocl
    i have ordered my car kit so if the weather is nice at the weekend (which i dont think its going to be [img]/ubbthreads/images/graemlins/frown.gif[/img] ) i will have a go at fitting.
    Feb 2004
    Leeds, Leeds, Leeds
    69
    Jedi
    I have a pre facelift 2000 S3 so don't know if this makes a difference to the wiring to the stereo. There definitely is an ignition live though cos i took my turbo timer feed off of it too.
    If you pop out the lenses of the lights you will see a couple of philips screws in there. Take these out and the whole light assembly will pull out. Its straight forward to do, honestly it was the easiest part of the install. (This is all based on the fact that we have the same curtousy light set up)
    I aren't sure what kit mine was cos i bought it off Garth_S3 who's a forum member.
    Do a search on my posts and find the post about car kits. On that thread Garth S3 points out a couple of sites that may help you.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    try www.justcarkits.com for the loom
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    i would never get it fitted by a 'professional' my dad took his car to get one installed and they made a crap job.
    i'd rather learn how to do it myself and take a day doing it carefully!
    Oct 2003
    Channel Islands
    213
    [ QUOTE ]
    [/ QUOTE ]
    Agreed, same with ICE installs, I would always consider myself far more careful than some cock knocker at an installer, who only wants to bang the job out as quickly as possible.
    Plus the skills gained learning the proper way of doing it are invaluable.
    Feb 2004
    Leeds, Leeds, Leeds
    69
    [ QUOTE ]
    [/ QUOTE ]
    Exactly right. Job satisfaction is a great thing. Plus the money you save can buy a couple (if not three), full tanks of optimax! [img]/ubbthreads/images/graemlins/woohoo.gif[/img]
    Feb 2004
    Leeds, Leeds, Leeds
    69
    [ QUOTE ]
    [/ QUOTE ]
    Tested this out last night. Stereo doesn't switch on as such but car kit works as usual with sound coming through the front speakers
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    ah thats cool. does it turn the display on to say phone?
    also do you hear the phone ring through the speakers as normal?
    ta.. thanks for your research
    phydaux's Avatar
    Aug 2005
    Sydney Australia
    16
    Just be careful, when the guy fitted mine he said that if you turn the power on with the glovebox dismantled the on off connection for the airbag has a fit and will need to be reset by Audi. Not totally sure how or why but if you have one proceed with care.
    Hello to everyone!
    Feb 2004
    Leeds, Leeds, Leeds
    69
    Same here, I think i just switched mine off before taking the glove box out.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    thanks... i bought the ck-7w kit at the weekend. just buying the power / sound through speakers interface now so i should be able to install it all one evening or weekend at the latest
