EM TuningMonster Motorsport
Results 1 to 7 of 7
    Apr 2011
    Bridgwater, Somerset ENGLAND
    56
    Loose wire in loom (with injector wiring) please help!!!
    As above, i replaced my injector seals and when stripping out i found a section of wire poked down through the inlet manifold, it was in the loom with the four injector connectors and cam pos sensor, havent got a clue where it came from!!
    http://i218.photobucket.com/albums/c...2/IMG_0261.jpg
    its the one i have trailed across the inlet manifold, the other wire in the loom is the cam position sensor, which is connected....(ignore the one by my hand, found where that went, i think lol)
    Apr 2011
    56
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    If you mean the one lead across the inlet manifold then thats the knock sensor wiring... knock sensor 1 to be exact...
    <tuffty/>
    Apr 2011
    56
    cheers mate, now, where do i find the sensor its come from...
    Apr 2011
    56
    knock sensor location? do i need to remove the inlet manifold...again?
    as above, found the wiring disconnected, cant find the location of the sensor so i didnt wanna take off the mani if i dint need to?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    To the right of the thermostat housing on the block
    VWVortex.com - JETTA 1.8T 2001 knock Sensor.
    <tuffty/>
    Apr 2011
    56
    will investigate tomo cheers buddy
  1. 1.9TDI injector loom
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2011, 22:17
  2. Injector rail loom
    By AudiiduA in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2011, 22:43
  3. Price on injector wiring loom for 2006 2.0 TDI
    By Rigla in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 11:38
  4. 2.0 tdi injectors/injector loom
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2010, 22:32
  5. Injector wiring loom
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2009, 09:03
