JMB RetrofitsChris Nott
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Westy
Thread: Home made boost leak tester.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Ok, I've got to the stage where I'm fed up of boost leaks appearing every other week and am thinking about making a boost leak tester for home.
    Now as far as getting compressed air into the boost system can I use something as simple as an electronic tyre inflater as I wont need much more than 30psi. Or will it be better to invest in a small air compressor?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    the compressor will fill the system quicker than the tyre inflater but a good tyre inflater will do just as good a job getting the air in for you to find leaks.
    Since you do LNM, It might be worth investing in a tidy 2hp 50litre or so compressor for some basic air tools.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Westy's Avatar
    Dec 2008
    17,273
    I'm thinking that if I spend £80ish on something like this:
    Ring Heavy Duty Car Tyre Air Compressor Inflator RAC900 | eBay
    That I might as well buy something like this:
    Einhell 40.205.05 200/24 Oil Free Air Compressor 24 Litre
    JimS3 likes this.
    S3 Build Thread
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    I have a boost leak tester that you can have for cheap m8 PM me
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    clear ya inbox m8
    Westy's Avatar
    Dec 2008
    17,273
    Done matey
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,273
    Ok, tester kit now sorted. Thanks Si.
    Back to compressor choice. I've been made aware of this one:
    eBay - The UK's Online Marketplace
    S3 Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    A tyre inflator wont cut it. The engine leaks down anyway thru the valves and piston rings, so you need to get the air in there quickly, which means you need a compressor with a storage tank. Its also much better to be able to charge the tank, shut the compressor power off, and do the leak test using the stored air so you can hear any hissing of escaping boost without the compressor rattling away in your ear.
    Either one you've linked is probably ok. The second one claims to be more powerful (2hp rather than 1.5) but its also some unheard of brand, whereas i have heard of einhell before.
    TD5 Land Rover Defender build
    Westy's Avatar
    Dec 2008
    17,273
    I'll be running the air through the FMIC boost hoses from charge pipe to inlet mani so wont be loosing any through the seals.
    I think i'll go for the 2hp one and can hopefully rig up a few air tools too.
    S3 Build Thread
    "Stick a V8 in it!"
    15,370
    Surely it makes sense to test everything including the manifold gaskets and injector seals?
    Simply remove the maf and fit the tester in its place, blank the PCV line and pressurise the lot.
    Westy's Avatar
    Dec 2008
    17,273
    Can do I suppose. I'm scared that will uncover even more leaks then just the boost hoses
    S3 Build Thread
    "Stick a V8 in it!"
    15,370
    Well the point is to test the whole system as it is on the car.
    By removing the pipes, testing them as a closed circuit, then reconnecting, you dont actually know for instance if your clamps are tight enough once reattached, and the moving around of everything could disturb components.
    By testing the complete circuit attached to the engine as it will be when your actually driving, your covering everything, including any potentially hidden split hoses under the manifold or even a leaking gasket or whatever.
    May 2010
    Bedford
    2,877
    All this effort and talk of buying compressors..can you not just take it to get smoke tested? lol
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Jason.s View Post
    I am Jason, Booked in to see Bill in January.
    I'm thinking about for the future and also with the ability to use some air tools too.
    S3 Build Thread
    May 2010
    Bedford
    2,877
    Fair enough. The prospect of airtools at home is pretty awesome. Even when i borrowed a mates electric impact wrench it was pretty sweet. Made things so much quicker and easier when i did my clutch on the Civic.
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    i fired the pistons out of my brakes this weekend with an air compressor - interesting
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Alex C View Post
    I had to fire mine out with a foot pump, so this compressor will make things a lot easier.
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    yeah, i had fun trying to blow the last piston out with 3 blank cylinders. Now I, like you were, are flumaxed by the dam dustboots
    Alex S3 AMK
  1. Smoke tester for boost leaks !!!!!
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2014, 16:57
  2. Anyone in the NW with a boost leak tester or an air compressor?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2011, 17:16
  3. home made boost tester ?
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 18:14
  4. Boost leak tester?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:30
  5. home made manifold
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2005, 00:54
