Badger5EM Tuning
Results 1 to 9 of 9
    May 2010
    65
    wiring up recaros in my a3
    hey, have just bought a set of front recaros and im just wondering will the extra connectors (needed by the seats) be on the cars loom as i have no electric seats and these are fully electric (and heated) or would some more wiring up be necessary? dont have much time to work on it so want to get it all done in one ideally thanks guys.
    Jul 2011
    middlesbrough
    112
    i have done the same about a week ago, the only wires already there are the air bad lights, you need to run some power from the fuse board or relay board, i taken mine from a relay that wasnt been used and put a inline fuse in. Then ran them to the seats.. You only need a posative and negative to get the electric seats working...
    May 2010
    65
    Thanks mate, it's the heating elements that's got me a little stumped... Will probably need to make a mini loom between the seats and switches
    May 2009
    Midlands
    197
    Quote Originally Posted by lewis88 View Post
    If your seats have the green connector underneath For the heated seat loom and you have got the heated seat switches then you can buy the correct loom from Kufatec, here's the link :-)
    KUFATEC GmbH & Co. KG - Kabelsatz Sitzheizung Audi A3 8L 30000
    Ben
    May 2010
    65
    Hey thanks Ben I will be purchasing the switches ready to link up the wiring will have a look at that loom
    May 2009
    Midlands
    197
    No worries mate, for 49euros plus postage you get the ready made loom with all correct connectors :-D
    May 2010
    65
    the only connector i have tho is the air bag one, so would i just give it a positive(fused) and a ground and it would work? im thinking the the loom wouldn't go as far as the dash to wire up my switches which i intend to buy
    May 2009
    Midlands
    197
    I've not got much of a clue when it comes to electrics TBH, its just in your initial post you said you had the heated seat elements, I assumed you had the connectors under the seat also, although I am sure someone will be able to answer your question.
    Jul 2011
    middlesbrough
    112
    i will take a pic of mine tomorrow mate, basically you will see on the yellow plug 2 wires are together and one is on its own just do the same i had to chop them as the connectors were different and use some spade connectors, no airbag light came on.. i will take a picture tomorrow...
  1. Wiring Recaros
    By SDO in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2009, 22:15
  2. recaros in a s3
    By aldo286 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2009, 00:27
  3. Replies: 3
    Last Post: 2nd April 2006, 19:25
  4. S3 Recaros in A3...
    By bowser134 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2005, 23:06
  5. Recaros
    By TDI-line in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th March 2005, 19:39
