JMB RetrofitsAH Fabrications
Results 1 to 13 of 13
    Dec 2009
    21
    Complications of running different profile tyres with haldex?
    Ive got hold of some genuine rstt's to refurb with two almost new 225 45 18 tyres. Going to get the wheels powdercoated and fit a full set of new rubber. In the meantime I was wondering if I could get away with running the 45 profile tyres on the rear of my current Reps and 225 40 18s that I run on the front? heared it could cause problems with the haldex and rolling radius etc. Anyone shine some light?
    Cheers,
    Jon
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    The Haldex allows for a 5% difference in rolling radius to take into account of tyre wear, you should be fine with the above tyres, there's a 3.6% difference in rolling radius if they are both the same tread depth. I wouldn't do it personally, so entirely upto you.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    You shouldn't mix tyres like that on any car with or without Haldex.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    why not?
    Many cars leave the factory with different sized tyres on the front/rear, and a few with different sized wheels too.
    As for haldex, cant you simply disable the whole system by removing the fuse? If thats good enough for running a car on a dyno in FWD mode, i cant see why it wouldnt be fine with slightly different tyre sizes front/rear.
    TD5 Land Rover Defender build
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    why not?
    Agreed many do, but only as the manufacturer intended, suspension, geometry aligned to account for it etc.
    A tyre profile is a percentage of the tyre width, many cars with staggered wheel set-ups (wider on the rear) will have different profiles but will still maintain the same actual profile measurement and keeping the rolling circumfrance the same on front and rear wheels.
    The same cannot be said of what the OP is suggesting.
    "Stick a V8 in it!"
    15,391
    True.
    It might cause issues with the ABS too, depending how different they are.
    To be honest, when i first read the post i read it as 225 45 17 and 225 40 18, which are almost the same diameter, and should be perfectly interchangable.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    As a temporary measure, I think it would be ok short term. I wouldn't disconnect the Haldex for this. Actually this has reminded me! I was running 2x19" rims on the rear and 2x16" at the front whilst getting a pair of rims refurbed, only drove it like that for a couple of days pootling about, no issues whatsoever, even though the front was sat a lot lower than the back!
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    could drive with the handbrake one click on to disable the haldex?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Is that true?
    does that work???!
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    AFAIK if the handbrake swith shows that the handbrake is on ( i.e. your handbrake light is on) then the haldex is disabled
    Alex S3 AMK
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    just take the fuse out, surely thats the best way?
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    possibly yeah, the handbrake switch being on will probably affect your ABS also
    Alex S3 AMK
  1. 8J rims...what tyres are you running?
    By jcb in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2013, 16:12
  2. 18" RS6 wheels - bigger profile tyres?
    By Naj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2011, 14:43
  3. Running odd tyres on a quattro.
    By sonnyjim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 01:59
  4. S3 on 18" RS4'S, which profile tyres?
    By benh999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2009, 23:41
  5. 8J rims...what tyres you running?
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2008, 22:38
