Monster MotorsportEM Tuning
Results 1 to 11 of 11
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Clutch Pedal - Very strange...
    Something quite odd happened when I got back to my car this evening at the station.
    I jumped in the car and went to put my foot on the clutch before starting her up as normal, but the clutch pedal wasn't where it normally is, it was weird I actually thought at first i'd accidentally moved my seat back, but then I realised the clutch pedal was fully depressed.
    Now I know the clutch pedals are prone to breaking in these cars and the clutch master cylinders can give up too, but the when I bent down and grabbed the pedal it just came back up with a slight pull. It seemed to be jammed/stuck, but I have no mat in at the moment and I can't find any reason for it to have got jammed.
    I drove it home without issues and went to the shop and it seems fine.
    Has anybody else experienced this before or is it a first symptom of something worse to come?
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes its been mentioned before without further incident....
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    This may not be much help but that used to happen to my fiesta, turned out to an hydraulic issue. Just bled the clutch and it never returned. Probably not much help since different car but worth mentioning.
    Chris-gsxr's Avatar
    Oct 2012
    57
    Any more on this? It just happened to my 09 a3 s line
    Dec 2010
    11
    Hi Chris,
    Like Gops has mentioned if the pedal can be lifted back up then works as normal this will generally mean that there is a hydraulic issue. Worst case the slave bearing within the bellhousing is leaking - gearbox needs to come out for replacement. Your best bet is to bleed the clutch then monitor it. If its still occuring follow the clutch lines from the master cylinder to the gearbox and ensure there aren't any external leaks. If you can't see any and your really keen you can disconnect the feed to the master cylinder at the brake fluid resevoir, catch the escaping brake fluid then attach a clear container to the feed and fill to a set level and mark this on the container. Then actuate the pedal 10 times or so and see whether the level drops. If so you've got a leak somewhere. If not then you need to check the crank end float and cross all your fingers and toes while doing so.
    Cheers,
    Patrick.
    Chris-gsxr's Avatar
    Oct 2012
    57
    It's only happened once so hopefully it's nothing to serious. Ill see how it goes over the the next few weeks. Cheers for the info
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Mine did this within a month of first buying it and saw it twice in five years after that so I wouldn't be too concerned. (8L)
    Chris-gsxr's Avatar
    Oct 2012
    57
    Quote Originally Posted by voorhees View Post
    Now that's the type of answer I was hoping for. I'm a fan of the "ignore it and hope it goes away approach". Lol
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Quote Originally Posted by Chris-gsxr View Post
    ha ha yeah works to an extent but I know if it was crunching into gear or staying down all the time I'd be after a new pedal/cylinder Chris
    Chris-gsxr's Avatar
    Oct 2012
    57
    Ye I'm only kidding. It's fine not. It was really strange. I changed down from 3rd to 2nd and the pedal was kind of stuck. Only for a second. I pushed it again and it popped back up and has been fine since. It goes into gear fine so I'm hoping for the best but if it happens again ill have it looked at.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Oh and ermm your 09 model is 6 years ahead of this sections last models Chris
  1. strange knocking wipers/brake pedal
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2011, 17:16
  2. Clutch Pedal and Brake pedal problem
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 08:25
  3. Strange clutch pedal problem
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2008, 19:56
  4. Dead Pedal ie pedal left of the clutch
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2007, 18:26
  5. A3 brake pedal strange feeling
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2004, 19:01
