Monster MotorsportChris Nott
Thread: Haldex oil leak
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Haldex oil leak
    Got a bit of an issue
    Finally got around to changing my haldex oil and filter as my wheels were locking up on turning. Not that hard of a job and it cured my locking issues, happy days. But next day noticed a blotch of haldex oil on the drive, far more than in if was just over filled. Then more and more over the next week or so. Im worried that my haldex is now running dangerously low on oil.
    Im 99% sure the filter and fill screws were secured properly and I cant see where its coming from. Has anyone else had this issue and is it safe to drive?
    S3Zek's Avatar
    Sep 2011
    407
    i remember when i did mine i did the filter up and it seemed to stop and i didnt want to over do it so had it on a ramp to check for leaks the next day and noticed there was a very small damp pacth of oil on the under side on the unit, ckecked the filter and i could do it up half a turn more fine after that, so worth checking again
    May 2010
    Galway
    139
    Right, must check that again so. It did seem to dump a LOT of oil though rather that a few drips.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Have you got it back up to check where it's coming from? I cross threaded my haldex sump plug when refitting so best to check just incase.
    May 2010
    Galway
    139
    Ive just crawled under to have a look but I cant see any any particular place that its coming from. Its not obvious like out of the sump plug. I really need to get it on a lift or over a ramp.
  1. Haldex oil and rear diff oil help ?
    By Daniel Thomson in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 16:26
  2. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  3. Leak following Haldex oil change
    By NEiLS3LK51 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2009, 19:56
  4. haldex leak
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2008, 17:25
  5. Metal Impeller Waterpump & Haldex Oil filter/Oil
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2007, 17:08
