Volks AutosMonster Motorsport
Results 1 to 34 of 34
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Smoke tester for boost leaks !!!!!
    Does anybody know where I can get a smoke tester from???
    I've a few boost leaks but can't find anything obvious
    Or does anybody have one I could use ?
    Don't have enough time to fanny around with a garage so thought I'd try and buy one but don't even really know what I'm looking for
    All help would be appreciated thanx lads
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    Chugger
    North Devon
    2,716
    I think they are a Fair bit of money mate, like 600 plus. Think badger 5 got one fairly recently. Most tuning/development garages will have one, cost me £25 to get mine tested, which just revealed Pcv leaks.
    I bought a tester kit off German eBay, which was just the adapters for pressure gauge and tyre valve which also does the trick, but no smoke.
    57 A3 2.0 TDI Sportback (140)
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Have you got access to a compressor? It would be easier to just do a pressure test then a smoke test.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by Westy View Post
    How do you go about doing this mate
    As I have access to a compressor
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Can vouch for them being expensive... Bill 'invested' in one... they are not a particularly cheap DIY option to buy for yourself...
    They are brilliant though... :D
    <tuffty/>
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by sportstractor View Post
    Ouch 600 il be giving that miss lol
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by AARON77 View Post
    It's pretty basic. you need a bung with attachment to put the compressor on. This goes in one end of the boost system, silicone hose after charge pipe. Then you need a bung for the other end, hose that goes onto the TB. Put 30 odd psi through it and listen for air p!ssing out.
    S3 Build Thread
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    I have a kit that will be up for sale very shortly, as soon as I get back int he country. It will let you pressurise and check for leaks, but no smoke. PM me if you're interested!
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Chugger
    North Devon
    2,716
    This is what iv got, works great if you have got a silicone tip. Although it does pass through the turbo seals.
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Thanx for your imput guys
    Spent 3 hours refiting hoses and clips and all is a lot better
    From 14 psi to this
    27,086
    Smoke pressure kit is between £7-800 last time I checked & tbh its far better than air based version as such, as you can see immediately where it is leaking, wish I had 1 tbh as I made one up, works fine but for small leaks you could never really find the leak that easily.
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Tooooooo much ££££££££
    Westy's Avatar
    Dec 2008
    17,273
    From 14 psi to this
    Brilliant results mate. I'm only holding 16psi at the moment and I'm sure I have some leaks somewhere.
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Normally get 22.8 on a good day
    U gonna have to get ya hands dirty dude
    Westy's Avatar
    Dec 2008
    17,273
    Could you hear the air rushing out of the leaks? I used to get 21psi but the track day at bedford last month seems to have loosened the hoses somewhere.
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    I didn't use a tester just pissed around with all the hoses till I got the rite one
    Just got in and it's reading 22.6
    Westy's Avatar
    Dec 2008
    17,273
    All FMIC hoses was it? I need to change over the clips I'm using as I'm not a fan of the T-clamp things I'm currently using.
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Ive not done a fmic yet
    I've modified the hose unto my throttle body and that was the culprit
    Westy's Avatar
    Dec 2008
    17,273
    Ahh ok mate. I've got my work cut out then! I've got a FMIC, catch can, and every othe boost hose has been replaced!
    I'll get the bumper off one night this week and have a real good look. Cheers.
    S3 Build Thread
    Chugger
    North Devon
    2,716
    are you guys running stage 2 plus? because according to vagcom im only seeing 17-18 psi. Dont know who mapped my car
    Westy's Avatar
    Dec 2008
    17,273
    Mine is revo stage 2 software, mapped at Badger 5. Bill mapped mine to 21psi as my old FMIC wasn't cooling the charge air too much and my fuel pump was failing. I'm visiting him in January for a health check and map tweaking now I have a new fuel pump and bigger FMIC so shoul get more boost put in the map.
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    I'm running stage 1 revo but have upped the boost
    Dec 2013
    Birmingham
    24
    Anyone know of any places in Birmingham that can carry out a smoke test? Thanks
    27,086
    I know its the expensive route, but audi usually have smoke testers as I've used there's before
    Dec 2013
    Birmingham
    24
    Thanks for the reply Nigel, do you remember approx how much they charged?
    27,086
    I'll be honest, I got it foc as I know the master tech at my dealer guys due to business etc
    But all comes down to hourly charges with audi, a leak test would be 30 mins to 1 hour max, if that as a leak should be very apparent in 5 minutes flat.
  28. #27
    Dec 2013
    Birmingham
    24
    Damn, good to know people in the right places lol
    Thanks anyway Nigel I'll see what Audi quote me
  29. #28
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Whereabout in Birmingham are you?
    I know its not in Brum, but R-Tech in Hinckley defo have one.
    What seems to be the issue with the car (which car is it?)
  30. #29
    Dec 2013
    Birmingham
    24
    5 mins away from city centre Nilz
    The car is a 1.9tdi SE 55plate BKC 120,000 on the clock
    I feel as tho there's a lack of power I say that because my mate has the exact same car but in sport and his car feels much more poky (his car has 95,000 on the clock don't know if that is the reason why) and I can sometimes hear wind noise, like wind escaping from somewhere but not sure if that's just my ears lol
    My first diesel so don't know if I'm just being a noob sorry
  31. #30
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Have you tried the 8P forum too? you are currently in the 8L section which is A3's to 2003...
    <tuffty/>
  32. #31
    Dec 2013
    Birmingham
    24
    Oh woops sorry I didn't realise I'll try the 8p section thanks
  33. #32
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Where I work does smoke testing pm me mate
  34. #33
    Artsa's Avatar
    Sep 2013
    Chepstow
    156
    Tuffty found loads of leaks on my S3 last weekend at Bills...
  35. #34
    Nilz's Avatar
    Apr 2006
    10,087
    If you are still reading this, get in touch with Lee, top bloke who will look after you
  1. Anyone in the NW with a boost leak tester or an air compressor?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2011, 17:16
  2. boost leaks, what can the effects be?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2010, 18:28
  3. home made boost tester ?
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 18:14
  4. Boost leak tester?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:30
  5. boost leaks?
    By xxbmxlsxx in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2008, 19:53
