EM TuningAH Fabrications
Results 1 to 7 of 7
Thread: Audi a3 lambada
    Aug 2010
    30
    Audi a3 lambada
    Got codes 17522 17511 17584,I take it my pre cat sensor has gone. The mpg has definitely gone down also
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Lambada is a dance mate....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    17511/P1103/004355 - Ross-Tech Wiki
    17584/P1176/004470 - Ross-Tech Wiki
    17522/P1114 - Ross-Tech Wiki
    Might be wiring as you have codes for bank 1 S1 and S2... this is both lambdas... S1 being pre-cat and S2 being post cat...
    For that many faults I would be tempted to check the wiring first... clean plugs up etc...
    Had any work done on the car recently? what year/engine code A3?
    <tuffty/>
    Aug 2010
    30
    2000 aum
    Been getting fault code 16804 every now and again for about 4 months
    Work done
    N249 delete
    Replaced vac pipes
    Recirc dump valve forge
    Injector seals
    Temp sender
    Boost pipes & tip
    3" down pipe
    Same code still came up ,as I had a vac Leak
    Changed thermostat as temperature wasn't heating up to required temp,it sorted that
    Then got fault code 16804 17522
    Cleared these
    Now got codes 17522 17511 17584
    Both sensors gone ?
    Already cleaned contacts with electrical contact cleaner when I changed downpipe over
    Aug 2010
    30
    Catch tank also been done
    Aug 2010
    30
    Any one know , how much they are
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    wideband lambda is around 80-100 quid iirc and post cat is 'cheaper'... have a look on euro car parts...
    <tuffty/>
  1. Audi a3 lambada sensor
    By stevie e in forum For Sale/Wanted - Audi Parts
    Last Post: 30th November 2011, 20:58
  2. de-cat the lambada sensors
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2010, 23:45
  3. lambada sensor fault
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2009, 12:31
