AH FabricationsChris Nott
Results 1 to 36 of 36
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Suspected Fuel pump/relay issues.
    Hi All,
    I walked out to the car tonight and turned the key, the car started for a second then cut out. It then wouldn't start at all. I suspect it might be the fuel pump or relay as I can normally hear the pump prime when I get in the car but I don't *think* it did tonight (I was on autopilot after work). Any way I checked the fuel pump fuse and it looked ok. I then removed the FPR to see if there was fuel in the rail, which there is. However if I try and start the car with the FPR out there is no movment in the fuel in the rail which I expected there should be (probably spraying out)?
    I'm off back to the car shortly to scan it but wondered if it does look like the pump/relay, is there a way of testing which one it is? Can I attach a volt meter to the top of the pump with the ignition on? If so what should I see when its working or fecked?
    Comments appreciated!
    Dave.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Sounds like an immobiliser cut tbh...
    <tuffty/>
    kite's Avatar
    Oct 2007
    East Berks
    675
    was the immobilisor light flashing.
    The car starts and cuts out when the immobilisor cuts in.
    A4 (b6) 2.5 TDi QS Saloon.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    The immobiliser light didn't flash. The car is now just turning and not firing. Is there a way to test the immobiliser and I assume it would throw a code if it was the immobiliser?
    > S3 225 (03) - OEM+
    View: My S3 diary
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    engine block will show if the immo triggered... immo normally works by firing then cutting the engine..
    VCDS scan first then we go from there
    <tuffty/>
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Ok, no fault codes found on the auto scan or the engine block....?
    When I turn the ignition key the immobiliser light comes on and then after a second or so disappears as normal.
    The fuel pump definitely does NOT prime when I open the door or turn the key in the ignition. I've checked fuse 28 and the other ignition fuses in the fuse board in the dashboard and they are fine.
    When I turn the key the car just turns over and over but doesn't fire.
    All I can think is either the pump relay (but I'd expect this to throw up some codes?) or the fuel pump?
    > S3 225 (03) - OEM+
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    when the ignition is on i would expect it to be pissing out of the void where the fpr was...i would say the pump is dead, out of interest how much fuel is in the tank?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Just over a quarter of a tank.
    > S3 225 (03) - OEM+
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    mine gets lazy starting if less than a quarter tank, (just if left overnight) so i suspect mine is on its way out,
    get the terminals checked on the fuel pump, if its live and the pump is quiet its the inevitable...
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I'm tempted to change the pump anyway as its been noisy for a while. I'll get it on a volt meter first to confirm though. Well that's another £200 to sink into the money pit!
    > S3 225 (03) - OEM+
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Funky_Junky View Post
    aye, the joys of motoring.....
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Ok, I now have the pump, has anyone got any tips or guides on fitting it?
    > S3 225 (03) - OEM+
    View: My S3 diary
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Westy has done this IIRC and wrote it up in his thread...
    <tuffty/>
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Cheers dude! I've had a look through his thread and it seems I have a problem, the fuel pump GSF have provided looks like this:
    ....which doesn't look like the one in Westy's thread....?
    > S3 225 (03) - OEM+
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Westys is probably out of a hotpoint washer dryier .....
    Just take yours out and see if they are similar?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    I've given up with ECP and the like after my heater matrix woes. I only get OEM parts now.
    When you have the correct part Dave it's fairly straight forward. Make sure battery is disconnected and fuel system has be de pressurised. You then access the pump via the access panel under the rear seats. Disconnect 2 hoses, unscrew a big black plastic seal, then lift old pump out. It can be a bit fiddly as there is a hose connected to the pump in the tank but you'll feel it once you've lifted the pump slightly.
    Get ready for a headache from the petrol fumes too
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    That doesn't look like a quattro pump lol....
    <tuffty/>
    Westy's Avatar
    Dec 2008
    17,274
    It needs 2 hose points on the top for a start!
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Actually...
    Maybe the GSF part means you have to swap over the fuel level sender? difficult to tell at this angle... OEM pumps come complete IIRC...
    <tuffty/>
    Westy's Avatar
    Dec 2008
    17,274
    This is why i'd rather spend the extra money for a like for like replacement. No head scratching and no wasted time.
    S3 Build Thread
    Jun 2011
    S.E. Melbourne/ Australia
    146
    That's what i've got as well when i replaced mine, you have to use your own fuel sender, top cap and hoses.
    Use steel clamps for the hoses.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    Westy's Avatar
    Dec 2008
    17,274
    No wonder it's a lot cheaper than the Genuine VW part!
    S3 Build Thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Well I had a crack at this today but gave up half way through. I managed to get as far as starting to remove the pump from the tank but then realised the point about the GSF part only being the main pump rather than coming with the other gubbins. At that point I decided to leave it, get a refund on the GSF part and buy one from Audi, I really can't be bothered trying to crimp on new fuel lines, I can see that being riddled with potential issues!
    One question though, how does the pump assembly come out of that hole as it seems to big, is there a way of disconnecting it from something in the tank? I disconnected one of the fuel lines that runs to the other side of the tank but there is another that runs from the other side of the tank to the bottom of the pump assembly? Does this pull out?
    I appreciate this might seem like gibberish but it's hard to describe (it's hard to bloody see as well through the little hole whilst getting high on vPower).
    > S3 225 (03) - OEM+
    View: My S3 diary
    Westy's Avatar
    Dec 2008
    17,274
    Not a nice job is it
    It's hard to explain but there should only be two connections from the pump into the tank then you need to turn the pump and you can slide I'd all ou in 1 piece. I found it easier with another set of hands helping as it's difficult to manoeuvre the pump out and hold the tank float thing that is on a metal arm.
    S3 Build Thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Sorted! Managed to get a genuine pump from my local Seat dealership and within 30mins it was in and working. It's miles quieter than the creeky old one aswell.
    Thanks for the tips gents, job jobbed! :-)
    > S3 225 (03) - OEM+
    View: My S3 diary
    Westy's Avatar
    Dec 2008
    17,274
    Nice work Dave. I noticed that you can't even hear the pump prime when I fitted my new pump.
    S3 Build Thread
  28. #27
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Yeah I couldn't hear it when the back seat was back in, even with the seat out I could only hear a slight hum rather than the previous moan!
    > S3 225 (03) - OEM+
    View: My S3 diary
  29. #28
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    How much was the oem part pls
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
  30. #29
    Westy's Avatar
    Dec 2008
    17,274
    Quote Originally Posted by AARON77 View Post
    It's about £110 if I remember correctly but I think I had a discount too.
    S3 Build Thread
  31. #30
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by Westy View Post
    Oh that's well ok I can cope with that
  32. #31
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    It was £220 + vat, but I also managed to get a small discount.
    > S3 225 (03) - OEM+
    View: My S3 diary
  33. #32
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Yeah that's the figure I got when I did a search
    Ho hum it's all part n parcel lol
  34. #33
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Is it the same as seat Leon cupra R
  35. #34
    Westy's Avatar
    Dec 2008
    17,274
    Would have thought so as they have the same engines as us S's
    S3 Build Thread
  36. #35
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I'm not sure as the tank is different due to the prop running through the centre of it, as a result quattro cars have a second contraption in the other side of the tank. The part I got from seat was specifically for the 4wd leons that seat sell in other parts of Europe. 2wd pumps could be the same but I wouldn't risk it after my ordeal.
    > S3 225 (03) - OEM+
    View: My S3 diary
  37. #36
    Westy's Avatar
    Dec 2008
    17,274
    You are correct. I remember reading about quattro Leons being produced in Spain but not in the UK.
    S3 Build Thread
  1. Fuel Pump / Relay help
    By Aaronneal in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Days Ago, 16:10
  2. Fuel Pump Relay
    By scoobyra in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2010, 08:47
  3. Relay (for fuel pump) location?????
    By sam1014 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd February 2010, 08:18
  4. Fuel Pump Relay - Where is it?
    By E36graduate in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2009, 00:54
  5. fuel pump relay
    By richh in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2006, 16:36
