Chris NottEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    eddieantifreeze's Avatar
    Jul 2011
    164
    Quote Originally Posted by sekenzo View Post
    Fitted mine this week as well. Love the sound and the improved trottle response. Must admit it was quite an a** of a job to do. My sports cat for some reason is shorter then usual so the join between the downpipe and centre pipe does not mash up perfectly. Got to end up cutting a part of the centre pipe off and put an exhaust joiner in between. Then got to cut btw the catback and centre pipe to get the old pipe out and another join to link up the new centre pipe and catback.
    Is the standard catback restrictive? If it does not provide much performance gain changing it I may just keep the standard catback as I don't really want a loud system...
    I have an A3 1.8t btw
    At an educated guess (dont forget the word guess!) - the standard backbox does produce backpressure, but nowhere near as much as the standard cat. since you have a sports cat and no mid box personally i would keep the std backbox to retain some backpressure in the system, if you went for a sports backbox now it would be seriously loud! plus naff all backpressure which may reduce the life of your turbo....
    97 Green 1.8T - Stage 1 R-Tech map - SOLD
    2001 B5 RS4 Avant - Misano Red - SOLD
  3. #42
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    sorry for the bump. but i fitted one of these to my A3 1.8t. did anyone else notice that the tdi pipe seems a tiny bit smaller than the standard centre pipe as it doesn't fit in the sleeve as well?
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
  4. #43
    May 2010
    Bedford
    2,877
    Seemed fine to me when i fitted it other weekend.
    Does make a strange noise with the SAI going when cold lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  5. #44
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    Quote Originally Posted by Jason.s View Post
    Does make an AWFUL noise with the SAI going when cold lol.
    haha. sounds terrible with the SAI running!
  6. #45
    May 2010
    Bedford
    2,877
    haha truthfully corrected
    The mounts didnt line up very well from the crappy Euro`s pipe i got. I had to take off the rubber mounts on that beam and put some old bump stops cut down on each mounting peg and then bolt the beam back up haha. Pretty pikey but with my discount the pipe did only cost £9. Sounds alright when going, bit beefier, low speeds sounds a bit strange too but she hasnt complained yet so i dont care
  7. #46
    Steven.c's Avatar
    Sep 2011
    282
    Since ive fitted mine, it get like a rubbing sound when turning left. i know u will say its the wheels but strangely its not, never had the problem before and its only when i turn left and accelerate don't know why it wouldn't do it when i turn right tho. might stick the centre box back on and do a muffler delete instead.
  1. Replies: 23
    Last Post: 28th March 2011, 21:01
  2. Replace pick up pipe naturally, also clean oil feed / return pipe?
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 18:05
  3. custom down pipe or pipe werx down pipe
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2010, 20:23
  4. Split Pipe, But dont no the name of pipe! sounds like I have A Dump Valve!
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2009, 13:12
  5. Tube? Car? Tube? Car? ummmmm....
    By imported_CurryMilkShake in forum General Chat
    Last Post: 8th April 2006, 14:18
