Volks AutosSky Insurance
Results 1 to 17 of 17
    Dec 2010
    Lincolnshire
    62
    Lcr Brembo Ques ?
    Hi im going to be fitting my lcr brembos i got off ebay a few months ago .Just a quick question before i start will i need wheel spacers to clear the caliper at all there looks to be plenty of room behind the alloy im running 18" rstt rep alloys 8j wide. Any info would be great thanks
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,900
    Visit 16Klappe's Instagram Channel
    You will be fine with those.
    I quite often say I'm going to do things.
    Then never do them.
    Dec 2010
    Lincolnshire
    62
    Cheers for the quick mate . Ill get them fitted saturday .
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    there might be an issue with the offset depending on the clearance to the spokes... I have the Brembo GT kit, which i think is the same.
    My wheels cleared it ok, but only by about 1mm! I put on 3mm spacers just in case.
    ...... Waiting Paitently...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    I have AP 4 pots that aren't too dissimilar to LCR brembos size wise under OEM RSTT's (18x8, ET33)... they needed spacers to fit... 5mm at least
    My Avus's 'just' fitted with a fag paper of clearance but wouldn't want to run them without...
    The RSTT spokes aren't flat enough on the OEM wheels... not sure what they would be like on a set of reps as they are ET35 typically and so a bit flatter internally... you maybe lucky but I would be budgeting for spacers
    <tuffty/>
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    564
    Yip aftermarkets are defo closer. My Avus's have stacks of clearance.
    Dec 2010
    Lincolnshire
    62
    mmmm ok so it will be tight then . So if i brought a set of 5mm spacers for the front will that be ok with the standard wheel bolts or will i need extended ones ?
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    I'd say so. I struggled to put my Brembo on, before subsequently taking them off again, and had 11mm spacers on the front and 16mm on the back. Main issue was over the aftermarket RS4 style wheel offset. The spokes just curl in towards the centre which meant almost no clearance even with my spacers.
    If you are going to tinker with the brakes though, I'd do the spacers at the same time as it's a great opportunity to improve stability and handling.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    you'll almost certainly need extended bolts for any spacer.
    The stock bolts are only just long enough to fully engage into the hub.
    TD5 Land Rover Defender build
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    564
    If you get extended bolts, make sure there not too long tho as I've heard somewhere they can damage the ABS ring or pick bind up somewhere if they go too far in...
    I'm not 100% on this, but just be careful either way.
    Dec 2010
    Lincolnshire
    62
    Ok thanks for the info guys . What size spacers would you recommend for best looks and driveability ? 10mm front and 15mm rear ? cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by Rick.S3 View Post
    I use these sizes on OEM RSTT's, 18x8 ET33
    <tuffty/>
    Apr 2010
    35
    Will these fit under std 17" avus wheels?
    LukeTripod87's Avatar
    Apr 2009
    Kent
    315
    i use 10mm front and 15mm rear both on my summer wheels and just put winter avus's on and they look a million times better as they sit in the arches too much i feel!
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Quote Originally Posted by rich4130 View Post
    id like to know this too.. and also can i use the std s3 discs?
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Yes, LCR brakes do fit under the 17" Avus. I ran my car that way for a while.
    No, as far as I'm aware you can't re-use your standard S3 front discs and you will need to buy 323mm ones.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    [IMG][/IMG]
    thats on standard avus! they do need spacers with RSTT reps.
  1. LCR Brembo brakes help/questions
    By JtotheD in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2011, 16:33
  2. LCR Front Brembo Set-up
    By Ryan_W in forum For Sale/Wanted - Miscellaneous
    Last Post: 7th July 2011, 22:13
  3. Following on from the LCR Top Mount info... ( LCR Wishbone Bushes )
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2011, 14:00
  4. Sorry - Another Ques Re RNS-E
    By Leenx in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2009, 22:28
  5. LCR / Brembo GT jr Discs
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2007, 18:05
