Volks AutosEM Tuning
Results 1 to 8 of 8
    Feb 2011
    14
    Need a new clutch, can anyone help recommend one??
    Good morning all,
    Before anyone comments with 'why dont you try using the search facility', i already have and im still struggling.....
    My standard clutch is slipping on my S3, which has recently had a FMIC and Revo stage 1 fitted.
    My question is what would be the best type of clutch to go for on this taking into consideration;
    - that I am toying with the idea of stage 2 (downpipe, sportscat and software) in the near future
    - not sure how long im going to keep the car itself (may get bored after a year or may run it into the ground?!)
    - budget isnt endless at this time of year (the daughter wants A LOT for christmas lol!)
    - i probably dont drive it as hard as i should, usually just potter to work and the gym.... but i would like to be able to drive it fairly hard if need be.
    If anyone could help this would be much appreciated and any links or part numbers would also be massively helpful. Once again sorry for the (what im assuming is a) common question!
    Sean
    colicabcadam
    standard clutch or equivalent sachs clutch will be fine, you only need an uprated clutch when you start playing wiht new turbos in my opinion
    however - if you are going to launch your car at every chance, you'll need an uprated one if you want it lo last
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Helix ceramic paddle clutch
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    valeo clutch kits are good for the money
    Nov 2011
    17
    Hope everything is ok for u
    Feb 2011
    14
    Thanks for the input guys, i will have a look today at some and start pricing up. Im not too clued up on these things but ive been advised to change the flywheel too, does this sound right? cheers
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    Yeah you should change your flywheel whilst you're there. Have just had my clutch/flywheel changed.
    To give you an idea for me it was..
    £129.99 + VAT for a SACHS clutch
    £249.99 + VAT for a Dual Mass Flywheel
    £20.00 + VAT for the release bearing
    Then fitting on top unless you're doing it yourself.
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by harrsf View Post
    I have a light fly wheel
  1. What do you recommend
    By TrickyLad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2011, 13:37
  2. Recommend me an upgrade!
    By jojo in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 25th March 2011, 14:27
  3. can anyone recommend......
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2008, 10:21
  4. Can anyone recommend ....
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2007, 00:55
  5. Can anyone recommend?
    By Drystone in forum Other Brands & Models
    Last Post: 26th February 2003, 23:01
