Chris NottMonster Motorsport
    s3black's Avatar
    Aug 2011
    Scotland
    78
    Temperature sensor help please
    Just replaced my sensor today as meddle was rarely moving past 70 and it has made no difference at all.....Any thoughts as to what I need to do next?Thanks.
    SCOTLAND - Audi S3 2001
    Cat-back system, Coilovers, forge recirculating dump valve, stage one re-map.
    Back rolling on 17" Avus wheels
    Lewis583's Avatar
    Mar 2010
    870
    Thermostat and some fresh antifreeze if it hasn't been changed recently.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    s3black's Avatar
    Aug 2011
    Scotland
    78
    Cheers : ) had a chat with some peeps tonight and they had the same view....
    Nov 2008
    154
    Seconded - failed thermostat and failed temperature sender rather oddly cause the same symptoms.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Just gone through the same issues and it was the thermostat in the end whic it obviously is in your case.
  1. Outside Temperature sensor
    By 4 circle in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2010, 20:58
  2. Outside temperature sensor
    By cabriolet in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 22:00
  3. Temperature Sensor??
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2007, 21:08
  4. Temperature Sensor 2.8 V6
    By alex100a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th November 2006, 17:28
  5. Outside Temperature Display Sensor - Where is it?
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2005, 19:01
