EM TuningMonster Motorsport
Page 5 of 6 FirstFirst 123456 LastLast
Results 161 to 200 of 220
Like Tree9Likes
Thread: Hybrid turbocharger k04 build
  1. #161
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    Quote Originally Posted by slappy_dunbar View Post
    Yeah. And that's very true when it comes to Prawn. But if you can safely do a run, I'd like to see it. And as I said, it's a solid means for assessment of progress during a build (plus it's quite a bit of fun).
    I'll do a 3rd gear run and use the spreadsheet to work out a FATs time this evening Doug.
    Mine's an ENJ 02J 5 speed on 225/45/17's with what you guys on vortex would call a 'stock block tune'!
    I imagine being a 5 speed the FAT's time will be considerably higher. Do any of the guys on vortex do FATs with the 5 speeds and F23 combo?
  3. #162
    RIP S3dave
    May 2004
    nr Glos
    7,156
    indeed its a solid gauge on same car same conditions.... Remembering overall weight on board is more of a factor than might be firstly apparent.. (I know our racecars I am involved with, weight is by far the biggest differentiator)
    handy for real world comparisons...
    luckily I have a dyno to see what works for me.. strapped down doing 150mph stationary.
    road logging is how I used to have to do stuff but a 450bhp polo made my mind up, it was daft... and only going to end in tears at some point.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  4. #163
    _G_
    _G_'s Avatar
    Jul 2011
    869
    bump - k04 hybrid project started! parts on order.
  5. #164
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Just been out logging for FATs times to see how they compare to the 6 speed, and I think it's safe to say it's wildly different! haha.
    Best FATS recorded was 4.64s, and 6.11s on actuator pressure only.
    What sort of speeds is the FATS test from on a 6 speed? on my 5 speed it's from 65-101mph. I'd imagine the 6 speed test is at a much lower speed.
  6. #165
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Can someone explain to me and karl what FATs are? Were only mere grease monkeys haha.
  7. #166
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    we are not worthy dani. lets go chew on a spanner
  8. #167
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    It's a performance measurement Dani, rather than relying on engine parameters to measure performance, this measures real world acceleration on the road using vagcom.
    FATs time is the time it takes to accelerate from 4200-6500rpm in 3rd gear.
    The little green spreadsheet above is used to work it out using vagcom log data, because recordings arnt always taken at exactly 4200 a d 6500, so it works out the time stamp at those points using the closest values either side.
    Because it measures in gear acceleration, it's only really comparable across cars with the same transmission, hence me asking about speeds at each rpm point. As I imagine on a 6 spd it'll be much lower speeds than the 65-101 on my 5 speed, sometimes are. Of comparable
  9. #168
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    similar to doing say 30-100 times or whatever.
    surely they would be better gauge of performance, as you are using more gears.
  10. #169
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thanks for that nick, didnt know you could do that with vag com.
  11. #170
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Just needs a log with a time stamp either side of 4200 and 6500, and of course the RPM.
    Chances are, if you do your logs in 3rd gear usually, you can already calculate the FATS from an old log
    Mark's S4 imolavant - FATS Calculator
  12. #171
    Feb 2011
    Portugal
    161
    Quote Originally Posted by beachbuggy View Post
    My car does the same that this is doing when the boost comes up at 3250Rpm the AFR goes lean, is this normal?
    I tune fuel with Lamfa, it's a narrowband ECU...
    In my case it doesn't goes to lean, because the fuel it's requested to be at 12.6 before the 3000 rpm zone... So I get +-14.00 when the boost comes up...
    Talking about the 800hp by 0-400 S3 : "Is it true that everytime you take this car down the strip, the earths rotation slows by 0.1 % ??"
  13. #172
    slappy_dunbar's Avatar
    Let's Do This
    Westchester Cty, New York USA
    229
    Based on the gearbox ratios, I show the 6spd in 3rd gear running from 55.5mph to 85.9mph. That's a good bit different than with your car. Maybe you should run in 2nd??
  14. #173
    beachbuggy's Avatar
    Surrey
    1,744
    So quick update. New 1bar actuator was fitted yesterday. Basically I bought a T3 actuator , remove the old one from the stock s3 bracket and welded the new one in place. 3 runs and the n75 was tuned to cope with the extra tension and now I can hold 23psi to the red line! Not only that the boost is definitely more aggressive I assume as the waste gate is being held full close rather than blowing open . So running today knocking a few degrees off the timing I managed 263grams, which I am very happy with. Work permitting I'll get down the RR next week to see how it goes.
  15. #174
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    excellent.
    whats the full spec of your car?
  16. #175
    beachbuggy's Avatar
    Surrey
    1,744
    Apy engine
    BAM ECU/loom
    ie forge rods
    xs power exhaust manifold
    3" blue flame dp/200cell cat and cat back
    b5 v1 tip
    welly cooler
    hydrid rs6/2283 ( unclipped) k04 turbo with uprated actuator.
    Blue haldex
    blistein springs and shocks
    brembo 4 pot brakes
  17. #176
    Let's Do This
    229
    Hah! Just goes to show you that an un-molested and un-clipped RS6 turbine rotor works just fine. So let's see some log graphs! What's your boost onset in 3rd? Airflow curve?
  18. #177
    beachbuggy's Avatar
    Surrey
    1,744
    Here you go.
    1) is the maf. as you can see at around the 4750 mark there is a real blip in the maf, this as you can see in 2) is at the point the cam changes from an advance of 23 degrees down to 1 degree..
    3) is the boost map. I have a slight over shoot but it's capped with a MBC at 23 psi ( this logger only goes to 22.5psi hence the flat line) and I found if I go over 21 psi below 4250 rpm the thing will surge if I keep it below that until around 4500 then I can ramp it up to what ever I want with out surge.
    As I now have an uprated actuator if I try and aim for 21psi, the KFLDRL map will always cause it to over shoot and surge because the N75 isn't quick enough. So I've set load map for around 18psi which means that when it tries to react to hold 18psi it will overshoot but stay within the surge limit 21psi and thus by the time is controls it,it'll be at 21psi anyway, if that makes sense?. No need for a clipped turbine. After 4750rpm I'm free to ride the PSI rodeo all the way to the redline..yeeehaaaa :-)
  19. #178
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    Impressive again! I think that answers my question about the mbc and the N249 bypass.
    Can't wait to start working on mine.
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  20. #179
    Jan 2013
    had a good read through this thread and fancy doing this to my partners TT, any news or updates at all?
  21. #180
    Let's Do This
    229
    Dan -- it'd be interesting to see your airflows compared when you have the intake cam "locked" into the two positions. I came away finding that the VVT system offered no benefit on the cammed FrankenTT. But that's a smaller-wheeled hybrid.
    Here's an example of how I logged the two settings:
  22. #181
    Jul 2013
    Thanks for such an intresting read looking at doing this myself as my turbo has just started smoking on hard boost. The only bit im woundering about is the machineing, as i dont have the bits in my hard i cant see but does the profile need reshaping aswell or can you get away with just turning it out?Thanks chris
  23. #182
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,081
    Add MIGGZ on Facebook
    just read thru this and very interesting build!
    did you not need to change inj or was the oem inj good enough?
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  24. #183
    Mar 2013
    Reviving an old thread I know, But is there a complete pre-balanced CHRA availible to build a hybrid?
    Seem these on Ebay,K04 Turbo CHRA Core Audi RS6 Cartridge 5304-970-0028/0029 077145703P 077145704k | eBay
    I'm sure there not the correct ones but just wondering if they are availible and at what price?
  25. #184
    Mar 2013
    Just spoke with Dan and now have an answer to the above.
  26. #185
    Apr 2011
    Michigan
    22
    Struggling with controlling boost, seeking help here:
    Even so the car is NOT an A3 (2003 A4 1.8T), here is the setup:
    Turbo: K04 turbine housing, machined for RS6 turbine wheel.
    Compressor: RS4 housing, custom fabbed to fit 2283 billet wheel
    550cc Bosch EV14
    High flow log manifold
    3" DP
    S4 MAF
    FMIC
    SAI, N249, N112, EGR/Kombivalve, removed, tuned out.
    Wastegate actuator: stock, starts to move at 4.5 psi
    Goal: constant 22 psi (MAP limit) to 7250 redline
    Tune: we were running into the 'calculated' EGT cut embedded into the Bosch/Audi ECU. Instead just blindly eliminating the threshold, we decided to measure and log the actual EGT at the manifold. Result: showing about 200 deg C lower actual than the calculated ones.
    Consciously raised the EGT threshold so it does not 'cut in'.
    The problem:
    a) N75 control not smooth at high rpm. Tried a few N75 (factory versions), but no significant change.
    b) switched to 'ball and spring' (intergrated engineering) MBC. Now experiencing: when MBC set to 22 psi, boost falls to 18 psi after 4500 rpm. When set to 25 psi (gauge), falls to 21 psi after 4500 rpm. Curves are almost parellel. Why are we 'overboosting' mid range (or NOT holding boost at high rpm)?
    Any suggestion how to achieve our goal to hold 22 psi to redline without too much overboosting (stock rods) at mid range?
    1998 Audi A4 1.8T Quattro, dark blue, K03/K04+ hybrid, Carbonio CAI, APR Inlet Tubes, APR R1 diverter, Turbo+Intake, T.A.P. 50 HP Chip 2, stock fuel, 20x6x2.75 FMIC, 18.5 psi @4000 rpm, Straight Pipe, 'sport' cat, Milltek CB Exh, Podi Boost Gauge, 17" OZ F1 225/45-17, PowerSlot Rotors, Hawk Pads, SB Stage III clutch
  27. #186
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    You need a good custom remap and you will be good to go even without mbc.
    You are probably hitting pid limits and some maps would need to be modified so the ecu can accept that much boost without interfering.
    Other thing that can cause that is boost variation.
    My info is based on research, I have somehow a similar prob.
    Audi S3 AMK
  28. #187
    RIP S3dave
    May 2004
    nr Glos
    7,156
    what ecu?
    whats being used to adjust maps?
    bill@badger5.co.uk
  29. #188
    RIP S3dave
    May 2004
    nr Glos
    7,156
    K16,7+7 BBT K04 hybrid, uprated actuator, Badger5 Ported to match the high flow exhaust manifold..
    Good work Dan
    jitvv likes this.
    bill@badger5.co.uk
  30. #189
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    ME7.5
    whats used...well mostly old stuff softwares and demo versions... (u probably know which). I have no access at all to a custom map or a tuner that does those ecu so when left on my own, I manage with what I have, which is un-cool lol
    please do correct me if my info about a custom remap needed for the member above is wrong.
    Audi S3 AMK
  31. #190
    Apr 2011
    Michigan
    22
    Here are some boost logs:
    N75 boost swing:
    https://www.dropbox.com/s/gdcygzk5bd...75%20swing.JPG
    MBC "up" (ca. 25 psi on gauge) vs. MBC "down" (ca. 22 psi on gauge):
    https://www.dropbox.com/s/xll3qalnxh...%20comparo.JPG
  32. #191
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Could pressure drop accross the cooler create that variance up top (assuming your using OEM positions) as boost control MBC/n75 and map sensor/boost gauge will see different relevant pressures?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  33. #192
    Apr 2011
    Michigan
    22
    what ecu?
    ECU: 8E0 909 518 AF
    Not sure what my tuner friend is using. But he says PID from scratch would require a TON of work.
    Respective data files from the logs shown are here:
    N75 swing:
    https://www.dropbox.com/s/vuqlb4ryay...5712%203rd.csv
    MBC "up":
    https://www.dropbox.com/s/gsb71oogsv...315_180327.csv
    MBC "down"
    https://www.dropbox.com/s/j1ntjfhbyx...316_000226.csv
  34. #193
    Apr 2011
    Michigan
    22
    Quote Originally Posted by StaceyS3 View Post
    Both (gauge and MAP) would see losses from FMIC. MAP should read higher (if any) since it does not see potential loss from TB (gauge tap is in manifold, MAP is before TB). MAP is limited to reading 22 psi (that is why the logs are 'cut off'); need to 'visually' extend the actual boost pressure beyond the 22 psi 'cut' line.
  35. #194
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by vtraudt View Post
    ECU: 8E0 909 518 AF
    N75 swing:
    MBC "up":
    MBC "down"
    If you are trying to sit closed loop control at limit of map sensor, I would suggest a different approach.
    Request looks to be high... , well at the limit of map sensor..so.. I would be looking at the actual N75% control map(s) personally.
    message me for more info if you want it.
    cheers
    bill@badger5.co.uk
  36. #195
    Apr 2011
    Michigan
    22
    550cc Bosch EV14
    3" DP
    S4 MAF
    FMIC
    The problem:
    Some suggested stiffer WG actuator spring (or additional external spring). Possible that WG is partially pushed open by back pressure at high rpm, causing the MBC to NOT hold pressure?
  37. #196
    beachbuggy's Avatar
    Surrey
    1,744
    Stock actuator is too weak to effectively control the boost, maxing the n75 dc and waste gate blowing open are conspiring against you.
    You are right , rewriting the the whole PIDS for an uprated actuator is a pig, but you do need a stronger waste gate.
    Then as said controlling n75 directly is the better/best option to get the boost profile you want...
  38. #197
    Apr 2011
    Michigan
    22
    That much back pressure form exhaust valve to turbine housing? Wow. Not sure what the closing force is of the stock actuator spring, but for example purpose: 1 square inch wastegate area, 10 lbs of closing force: back pressure must exceed 10 psi.
    What spring rate (crack open pressure) should we shoot for the actuator revision?
    In this context: what IS the spring rate (in N/mm or lb/inch) of the stock actuator?
    What spring rate (or spring) if adding an external spring?
    Are there any 'donor' actuators with higher (desired) spring rate to 'steel' (make/model/year/engine), even if 'adaption' (bracket, etc) is needed?
  39. #198
    RIP S3dave
    May 2004
    nr Glos
    7,156
    if I read the log posted correctly tho the n75% is hovering aroubnd 70-80%? for the 2550mb level?
    Did I read it right?
    Re Actuators, on k04 hybrids.. I prefer to sit around 12psi crack pressure... as a preference.
    bill@badger5.co.uk
  40. #199
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Sorry was wrote in a bit of a rush and wasn't that clear, but meant that the boost control IE the MBC could be seeing higher boost pressure pre cooler than ECU via MAP sensor and visually on the boost gauge after the cooler
  41. #200
    Apr 2011
    Michigan
    22
    cheers
    Not sure what actual N75 maps are, but here are the 2 N75 DC parameters I logged (before and after linearization) if that helps.
    https://www.dropbox.com/s/c6qbe2e30l...ty%20cycle.JPG
    Here is the boost and N75 DC for the N75 log:
  1. CR K04 Stage 4 Hybrid, comparison to k04
    By badger5 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2011, 15:38
  2. K04 hybrid
    By G"MAN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2009, 20:56
  3. Hybrid K04
    By vetch in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2009, 20:59
  4. k04 hybrid feeler....bt build
    By s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2009, 13:16
