AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    Oct 2010
    59
    replaced bulb and now brake lights stuck on !?
    just replaced a blown bulb went round the back to check all was well and realised now the brake lights appear to be permanently illuminated ? Any ideas chaps??
    1992 Cavalier SRi 8V RIP
    2002 Mondeo ST TDCi Good riddance!
    2000 A3 8L 17" Ronal TT, -45mm, LCR Splitter, Matt Black Badging, Soon to attempt Lamin-x headlight tints
    kite's Avatar
    Oct 2007
    East Berks
    675
    broken brake light switch...
    A4 (b6) 2.5 TDi QS Saloon.
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Had the same issue when I bought some cheap bulbs. Think the ones you need are P21W.
    Mineral Grey [
    AMK
    Oct 2010
    59
    did a brake light switch about 6 months ago broken again already??
    maz would that cause the circuit to connect when not needed? your S3 looks the ******** by the way
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Thanks Stu.
    All I know is when I fitted cheap rear bulbs recently my front and rear lights started to go nuts and those bulbs sorted it.
    Mineral Grey [
    AMK
    Oct 2010
    59
    ok cool will try tomorrow cant be arsed with another brake light switch pain in the arsed getting the right one 4th time lucky last time!!!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I had this on my old Ibiza, not sure if the S3 has the same bulbs but worth a check. Anyway, the bulbs in the Ibiza had double filaments - one filament runs the normal tail lights; the other (brighter) filament runs the brake lights. There should, in theory, only be one way of fitting the bulb into the holder so that everything works hunky-dory.
    Anyway, I managed to get my Ibiza bulb in the wrong way (i.e. by 180 degrees) and the net result was the brake light filament was permanently lit rather than the sidelight. Sorted by spinning the bulb back round through 180 degrees.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Oct 2010
    59
    JCS you little dancer! just saved me a weekend of cocking about with brake switches and bulbs! who'd have though you could put a bulb in the wrong way round?!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I'm guessing that worked then!
    Yeah, I was perplexed when I did it on my Ibiza. And in theory you shouldn't be able to put it in the wrong way around, but I guess brute force + ignorance can make anything fit!
    Jason
  1. hazard lights stuck on
    By mel_man in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2010, 19:26
  2. Any S3 owners replaced a bulb in the instrument cluster?
    By stevec in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2009, 10:48
  3. break lights
    By audi_driver in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2008, 03:58
  4. Reverse Lights Stuck On
    By mr_sjc in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2008, 10:51
  5. Indicator Lights Stuck!!
    By urban-audi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th February 2008, 19:32
