Sky InsuranceAH Fabrications
Results 1 to 17 of 17
    sc9
    Nov 2011
    6
    S3 Bose Audio Problems
    Hi, got a Y-plate S3 with Bose audio problems. Lots of them!
    The 6 cd changer in the boot doesn't open. The sub is bust. Three of the spleakers are blown completely and the fourth sounds pretty terrible. The FM radio reception is also very weak so I frequently can't pick up any stations.
    Bar putting a ghetto blaster on the back seat any recommendations on getting this sorted would be appreciated. Don't want to spend a fortune and don't really have tons of free time to invest either...
    Jun 2003
    World of my own
    9,813
    So some sort of "magic" solution would probably be best then, very low cost and is self installing!
    Is there any part of the Bose system that actually works? You say the changer won't open, do you mean the sliding door is jammed or that the cartridge won't eject?
    The lowest cost option would be find a breaker and replace everything like for like. Failing that you would need an aftermarket HU, 4 new speakers and a sub, which is not going to be either cheap or quick.
    Alex Turner
    sc9
    Nov 2011
    6
    Magic would be good - yet to find the right wand for this one though!
    I'm not sure if anything works really. I can't think of much that could go wrong with an arial (loop of wire..) so this would point to a fault on the HU I guess. Not sure how to tell what combination of parts are broken re the sub, amp and HU outputs.
    Pressing eject on the changer just doesn't do anything. Not sure of the reason here either.
    Thanks for suggestion that like for like replacement would be cheapest. Any idea of the Bose spec or would a breaker just pull the parts from another S3?
    Thanks again.
    sc9
    Nov 2011
    6
    I'm having trouble finding a breaker with the parts I need - will keep trying.. Assuming going directly to Bose would be too expensive has anyone any experience of easy-to-fit aftermarket speakers and amp?
    taylor1's Avatar
    Oct 2011
    37
    I got a a3 quattro and I haven't got a dick changer in my boot and I can't see a wire for one either I don't know what todo!! If I was you llook on eBay every few days as I seen 2 full sets of Bose speakers go on there for just under £50 and they looked mint.....there have been a set on there tho for ages for 50 but they look like a toddler has been using the cones and punch bags so I don't need to tell you to keep miles away from them haha
    Chugger
    North Devon
    2,716
    Quote Originally Posted by taylor1 View Post
    dick changer? Lol. Is that code for porn?
    Seriously though, to OP, I have a cd changer lying around that iv be willing to part with
    57 A3 2.0 TDI Sportback (140)
    Chugger
    North Devon
    2,716
    Quote Originally Posted by sc9 View Post
    There is no easy way mate, you can get new speakers but you will need to run adapters to fit them (andy mac supplies them) them power them direct off a new aftermarket HU, which would require new wiring to be run, which can be trick but not impossible. You can use an adapter to go on to the bose sub ( andy mac supplies them lol) which will give you use of the sub. Mine started going tits up so I did exactly this and now it sounds brilliant. The Bose system is ****e 8 years after birth, dunno if it sounded good when new, surely it must have!
    taylor1's Avatar
    Oct 2011
    37
    Lol classic....what a moron!!........I don't see a cable lose in the compartment tho??
    Chugger
    North Devon
    2,716
    If there is one, it will probably be behind the panel above the rear nearside wheel arch.
    taylor1's Avatar
    Oct 2011
    37
    Ye iv looked I'm starting to think that whoever bought it new didn't want a changer so they didn't add a wire on the build hmmmmmmmm
    Jun 2003
    World of my own
    9,813
    It's right at the back of the cubbyhole (towards the front of the car) past the rear seatbelt reel clipped to the bodywork:
    Not all A3's were pre-wired, early ones were, later ones weren't
    Alex Turner
    taylor1's Avatar
    Oct 2011
    37
    Awesome I only pulled the panel down and had a quick look thinking there would be a lose wire in there but now I see it's right in the rear quarter cards I'll have a look sometime it's not crappy weather
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    386
    People on here often break cars - look in the parts for sale section of the classifieds and PM someone breaking.
    2000 Plate Audi S3 1.8T Santorin Blue - 275BHP on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    sc9
    Nov 2011
    6
    Re: taylor1
    Haha - great typo! Not sure using a CD as some sort of dick replacement would go down that well though..
    Cheers for the ebay suggestion. The results pad out quite a lot when not putting S3 in as a search term but I'm not sure about the compatability and whether these from an A4 for example would fit:
    http://www.ebay.co.uk/itm/Audi-A4-S4-Bose-Door-Speakers-8EO-035-411A-2002-2005-/220907163939?pt=UK_In_Car_Technology&hash=item336f 17d123
    They do look about right..
    Are these the punch bag ones? They've got to be.
    Audi Bose Speakers | eBay
    Good luck to the fella trying to shift them!
    Re: sportstractor
    Thanks for cd changer offer. I'm not really all that fussed about a cd option and am more keen to get the radio working properly and an aux input for mp3. Still, I may give you a shout once the rest is sorted if someone else hasn't taken it.
    I'm also a bit afraid of the effort and potential for trashing the car to start adding cabling etc. Think am going to look for replacements as a first option. Prob need to be certain on the current setup -- there is an external amp isn't there and am assuming any old HU will fit if needed?
    Hopefully will be able to let you know how the system sounded at birth at some point. My guess is a bit artificial.
    sc9
    Nov 2011
    6
    Quote Originally Posted by Routledge View Post
    Good suggestion - will do that.
    taylor1's Avatar
    Oct 2011
    37
    lol ye there the punch bags haha been on hbere aaaages....you will have a prob finding some saying s3/a3 so i put audi bose and when a pic looks about ok for what im looking for i click.....thats where i fgound my replacements and it was in the ited discription it said the model
    Jun 2003
    World of my own
    9,813
    Well they are also for the 8P model, 8L front speakers are pretty rare for some reason. No they have to be from 8L no other speakers will fit.
    Alex Turner
  1. Bose Audio A3 8P
    By chrisby1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2011, 15:48
  2. Fitting BOSE audio in non bose audi?
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2010, 23:54
  3. BOSE UPGRADE TO JL AUDIO
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2010, 01:04
  4. Bose Audio
    By rub a dub in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2008, 13:33
