Sky InsuranceChris Nott
Results 1 to 18 of 18
    Nov 2011
    71
    High Mileage Turbo Advice
    Hello everyone im new to the site. To cut a long story short im selling my current car (Starlet GT Turbo) and wanting to buy my 1st S3. Around my neck of the woods (Blackpool), pickings are rather slim but ive found one in hyde with 132,000 miles on it (51 plate) with full service history, sav nav, leather, sun roof, and another one in huddesfield which has 134,000 on it (x plate i think) with full service history not as much kit, but had a recent turbo change, both are priced at £3,9995 in dealers and both have their plus points kit wise/turbo replacement. Can anyone offer me advice on the turbo front as ive not run a car turbo charged car with that many miles on it, i know the usual things to listen/check for turbo wise im just wary is all and unsure how long turbos will last. The one with turbo swap is tempting but equally the other one with all the kit is as well. Any advice welcome and thanks in advance.
    colicabcadam
    it ALL depends on the previous owners - if a car is warmed up correctly, cooled down correctly and the oil is changed regularly the turbo will last as long as the car
    a 10,000 mile old turbo can be in a worse condition than that of a 200,000 mile turbo, it totally depends on how it's been treated
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Im my exsperiance milage dosent mean a fat lot, are both the cars remapped? If so then its a hard one, id always go for the standard example and add to it, as i find a remaped car has usually took a thrashing. And 130k+ is Fine in these 1.8t, if its made it that far then it means its probly been well maintained. Good luck on your decision dude.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,282
    Quote Originally Posted by camscockle20vT View Post
    I agree with this. I bought my 51 plate S3 on 107K miles and it was ok until I got it remapped with a crappy generic map. The map was running very lean which meant that the turbo ended up getting so hot it had 3 massive cracks in it. I only discovered the damage when the turbo charger was sent off for a refurb and I ended up forking out for a new one! Not cheap.
    I would sway towards the car that's had the new turbo but I would also want to know if the reason that car needed a new turbo was for similar reasons to mine?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2011
    71
    Thanks for replies folks. As far as im aware both cars are standard, no mention of remaps being done on either car (although i will be checking the historys, asking the dealers etc) I did wonder if the car with the replacement turbo had been done as it had been thrashed.
    Westy's Avatar
    Dec 2008
    17,282
    Quote Originally Posted by Martin82 View Post
    On a standard car it will take a fair amount of thrashing to ruin the turbo.
    Usual turbo failures are from either the seals going or from the oil pickup pipe from the sump to the turbo blocking and causing the turbo to run dry.
    Ask the question as to why that car had to have a new blower fitted.
    S3 Build Thread
    Nov 2010
    1,673
    Quote Originally Posted by Westy View Post
    Hi westy, off topic question, but would a cracked exhaust mani cause a 1.8t to stall/lumpy idle? Iv got a fault reading for the pre cat lamba but been told its due to the cracked mani?
    Sorry to taint your thread martin. Good luck on your buy and id suggest doing abit of travelling to find the right one as there are some lovely standard examples for some rock bottom prices about now.
    Westy's Avatar
    Dec 2008
    17,282
    A cracked mani shouldn't cause any idling issues at all. Mine was checked when the new turbo was fitted but somehow it wasn't cracked which is quite rare as a lot of them tend to get hair line cracks at this age. If you can get hold of VCDS there are some lambda sensor tests you can do to determine where the problem is but I would expect your idle issue to be caused by something else.
    Anyway here is a few pics of my turbo after it had been cooked:
    S3 Build Thread
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    My cars done 157K and still pulls hard! But has been looked after throughout its life regardless of expense.
    Westy's Avatar
    Dec 2008
    17,282
    Quote Originally Posted by Gops View Post
    I bet if you sent it off for a refurb it would feel even better
    S3 Build Thread
    Nov 2010
    1,673
    Oooh that has more cracks than vaneesa felts deck chair dude, iv changed all my pcv pipes and still have a stalling issue, its intermitten and seems to change with the weather, i need to change my temp sensor, also i removed my coldside relocation kit and put it back to standard as it was saying leak from intercooler to throttle body and it goes into limp mode when upto temp, i unplug the maf and it goes out of limp mode but still stalls? Im well and truely boggled lol
    Westy's Avatar
    Dec 2008
    17,282
    I've had idle issues in the past and tried all the following things before I fixed the issue by replacing all 4 coil packs:
    - Clean and re-align Throttle Body
    - Change Temp sensor
    - Clean Injectors
    - Clean Fuel Pressure Regulator
    The coilpacks weren't causing any running issues on boost like normal or bringing up any errors in VCDS but the car would stall on cold mornings.
    S3 Build Thread
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Lol i was actually thinking about this earlier if im honest.. Wasn't too sure of costs and who would be the best to do it.. But it is on my wishlist (which is bigger than the list santa gets during xmas)!
    Westy's Avatar
    Dec 2008
    17,282
    I know that Bill uses CR turbos but I used Turbo Dynamics for mine. Look them up on the net. Both reputable companies and will only charge a couple hundred quid for a standard refurb.
    The expensive part is getting someone to remove and refit the turbo I you don't want to tackle it yourself.
    S3 Build Thread
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    I removed mine at 142k i belive, Sent it to Midland turbo on a exchange basis
    Black S3
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    This, but with another 40K miles.
    I quite often say I'm going to do things.
    Then never do them.
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    691
    I would check the paperwork for the turbo, make sure its not a snide ebay copy.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Nov 2011
    71
    Thanks to everyone for advice and thoughts appreciated, oh and those pics are horrifying Westy but certainly a reminder of how things can go wrong!
    Im angling more towards the one without the turbo replacement BUT as both are close to each other i'll be giving them both a look, plus any others which come up in the meantime.
  1. High mileage s3 advice?
    By Candy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2011, 20:07
  2. High Mileage or low mileage S3, which one to go for?
    By openside in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2011, 10:19
  3. Too high mileage?
    By robby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2010, 16:19
  4. High-Mileage TT?
    By AudiSport in forum TT/TT-S/TT-RS Forum
    Last Post: 23rd March 2008, 19:25
  5. High Mileage 1.8T
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2003, 12:52
