Badger5Chris Nott
Results 1 to 10 of 10
    Sep 2011
    49
    Removing transfer box
    Got a new flywheel and clutch for the car. When I drop the box out to do it do I need to remove the transfer box.
    If I do can it be done with out the special tool
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Needs the tool to undo the bolt in the middle of the drive flange (drivers side)... essentially a really long allen key... this needs to be removed to allow you to remove the bevel box...
    Looks like this...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Or make your own....6mm i think it is...
    I would not have thought you would need to split it as it all slides past the engine...just, but it will be heavy
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    It does slide to a point but its an arse... it catches the end of the block so you have to jostle it past... not that easy to do when the thing weighs so much... Was bad enough with 2 people and a lift ramp...
    As Dave says, its 6mm and you could make one from a long 6mm or some steel tube/bar with a bit of 6mm allen key welded on the end maybe... either way its easier to get the box off and back on again with the bevel box removed...
    <tuffty/>
    Sep 2011
    49
    How bigs the hole it needs to go down so I can get a nice bar and allen key I have a 5 inch 6mm allen key dunno if it's long enough
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    the hole is about 20mm in diameter and it needs to be a good 12" long
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Lmao is it just my dirty mind?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by camscockle20vT View Post
    you filthy brute....
    beachbuggy's Avatar
    Surrey
    1,745
    any idea where that tool can be gotten from?
    Jun 2009
    162
    I got my box out leaving the transfer box in place. Was a PITA to refit the box again, but can be done with a lot of swearing. Makes taking the gearbox out easier.
    The tool can be had at the dealers for around £9. Its VAG tool 1669.
    Good luck.
    A3 PD130 TDI Quattro - the discerning mans choice
    (or as I like to think of it the rarer more exclusive S3 derv edition)
  1. Allroad Transfer box diagram needed
    By jackdan20 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th June 2010, 12:47
  2. A6 C5 ALLROAD 2.7 T Transfer Box leak
    Last Post: 10th June 2010, 16:11
  3. Transfer box oil leak
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 10:36
  4. Allroad Transfer Box Seal Replacement
    By PeteS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th November 2009, 12:51
  5. Centre Diff/Transfer Box
    By Z82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2009, 16:26
