Chris NottVolks Autos
    Sep 2010
    89
    Briaded lines, fluid change, s3 312mm set up
    Alright guys
    I'm upgrading to a s3 break set up this week with braided lines, I want to change the
    break fluid rather then topping it up after I've done the lines as it's old so I'm guessing
    new will be better and boil at a Higher temp??
    I Was wondering if any one knew how much fluid I will need and is there a certain one to get or is it just dot 4?
    Vince
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Motul RBF 600 or 660 if you want something a little special else just use std DOT 4... 5.1 isn't worth the time of day compared to RBF 660 imo...
    If doing a full replace then 2 x 500ml bottles should do it but I have sometimes had to top up with a third...
    <tuffty/>
    Sep 2010
    89
    Cheers tuffty I'll check it out
  1. Brake fluid change
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2011, 19:39
  2. Brake Fluid change
    By GeoffT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2009, 18:24
  3. Brake Fluid Change
    By Roswell in forum Detailing
    Last Post: 7th July 2007, 17:36
  4. Quattro fluid change
    By mark88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2007, 13:24
  5. Brake Fluid Change
    By yoda in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2006, 15:19
