EM TuningBadger5
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    Could I use this clutch/flywheel combo on my S3 8L?
    Would I be able to get away with using this clutch/flywheel combo on my S3? On a budget and this would be perfect if so!
    VW VOLKSWAGEN GOLF 1.8TVR6 LUK CLUTCH & G60 FLYWHEEL | eBay
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Its a smaller clutch than the S3 one so hardly and upgrade... std (LuK) clutch was about £100 from GSF... dual mass more expensive of course but have seen a lot of probs with mismatched clutch and SMF combos... typically the clutch biting point ends up in the floor....
    I am not even sure its suitable for the 6 speed boxes anyway...
    <tuffty/>
    Nov 2011
    Horsham
    389
    Okay - I am trying to reduce the bill if possible as at the moment for a Sachs clutch, LuK DMF & release bearing incl. VAT i'm looking at £477.98 - That one at £150 saved me over £300!
    Nov 2011
    Horsham
    389
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Again...A3 is 228mm and S3 is 240mm...
    <tuffty/>
  1. whats the best audi s3 clutch and flywheel combo?
    By rydinator in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2011, 07:49
  2. New clutch and flywheel...
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd March 2011, 17:51
  3. Clutch And Flywheel
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 20:54
  4. Clutch And Flywheel
    Last Post: 7th April 2010, 14:38
  5. Clutch/Flywheel help??
    By Matty-YellowS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2010, 20:17
