Volks AutosBadger5
Results 1 to 19 of 19
    Jun 2011
    116
    Best (bright white) bulbs for headlight upgrade and sizes please? facelift 8L S3
    Hi folks.
    What are the best bright white bulbs to stick in the head lights? I'm after the same bright white light as my Xenons from all the bulbs.
    Looking to change
    main beam bulbs - Philips diamond vision maybe?? What size?
    side light bulbs - suggestions? size?
    indicator bulbs - i'll stick in silver visions, size?
    fog bulbs - suggestions? size?
    As it's a bumper off job i'll do the lot in one go.
    Help appreciated, cheers.
    Chris
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    I think the headlights on the standard s3 are 4.3K. 6K bulbs would be nice and white! I wondered this too as i think the lights are abit dim! As for the sidelights, i think they are 501's or ba9's.. im not sure, either way i'd recommend LED ones. You can actually get LED indicator lights too!
    Jun 2011
    116
    Hi mate,
    Not changing the xenon's, just the rest of the bulbs in the headlight's.
    Chris
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    If you ever want to change your xenon bulbs get 6000k, they are very white and look so much nicer than standard! (although i have 8000k). The type of bulb is called 'D2S', so search for D2S 6000k if you ever do fancy a change.
    For the sidelights you need '501' type bulbs and you should get xenon white led's. I got the following before on my car and they are so bright they pretty much light up the whole lens! They're pricey compared to others but they're bright xenon white and the brightest you can get!
    Go here, www.ultraleds.com - Go to search and paste this number in the box - U50115W
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    colicabcadam
    sorry to burst your bubble, but 4300 is the brightest colour you can get, google it !
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by colicabcadam View Post
    Very true, but look ****e
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Yep +1 he is correct as for the lights strangely the lower the K the brighter the light
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    Inertiauk's Avatar
    Mar 2011
    529
    Quote Originally Posted by rhubarb4 View Post
    Its not strange, higher K (colour temp) means more yellow removed, not more white added, hence light is removed.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    colicabcadam
    why do people dislike posts when they are wrong? a guy asked what the brightest white was - which is 4300k, not your suggestion of 6000k which has a hint of blue in it, oh well, spit your dummy out like a child then......
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Sorry mate, I only just seen that now.. I thought I pressed "like"! Sorry dude! Never really knew that as I seen some really bright white lights! So if I got 6000k it'll only just be whiter but no brighter than 4300k?
    colicabcadam
    lol - oh well - i am just in a bad mood this morning lol!!!
    4300 is basically the brightest colour with no visible yellow in it, 4000 would have a slight hint of yellow, 6000 is not whiter than 4300, it's got a hint of blue in it
    i admit that the higher colours look better (i have 8,000k on my ducati), but they produces less usable light - the standard set across the board was 4300, but as you can see, 4700 is a good colour too
    Jun 2011
    116
    Thanks for the post guys.
    Think I possibly mislead you all though.
    I want to leave the standard Xenon bulbs and get bulbs for the high beam and side lights which give a similar light to the Xenons.
    What bulb fitment are the bulbs for high beam? H7?
    What fitment would the indicator bulbs be?
    Thanks again
    Chris
    Jun 2011
    116
    Hi mate,
    The description lists the following so maybe best to stay away from these.
    Plastic body- not to be used close to a heat source i.e. headlight
    Quote Originally Posted by DJ_Troopa View Post
    colicabcadam
    this is what they are on an rs4 minus the HID bulbs - i believe they are the same across the board during that period
    High beam headlamp
    H7
    Parking light
    2886X
    3457ALL
    Front turn signal
    2827
    3457ALL
    Rear turn signal
    7506
    Tail light
    7528
    Stop light
    7528
    High mount stop light
    2825
    Fog/Driving light
    H7
    License plate
    6418
    Jun 2011
    116
    Spot on, thanks buddy
    colicabcadam
    i'd also go osram (you've made me buy some now) instead of phillips
    i bought these for mine
    H7 499 55w OSRAM COOL BLUE INTENSE Bulbs 12v -64210CBI x2 | eBay
    OSRAM W5W COOL BLUE SIDELIGHTS W5W OSRAM 501 12V 5W | eBay
    i wouldnt bother doing the indicators.....
    Jun 2011
    116
    Good buy mate, might just grab them then, give them a go, the xtreme vision bulbs are pricey.
    I don't like the fried egg look of the indicators, is it possible to change the high beam / side lights without wipping the bumper off?
    Chris
    colicabcadam
    yea - it is a squeeze but from what i remember you can - the side lights are the worst ones to do ! fogs are the easiest!
    flubbachany's Avatar
    Jan 2013
    Quote Originally Posted by Gops View Post
    Any recommendations for LED indicators and LED brake bulbs? I purchased a set of CANBUS LED indicators (front and rear) as well as CANBUS LED brake lights, but the car still didn't like them! Got the indicators hyperflashing with them installed (everything lights up, but the flash like mad), and the brake light throws a fault on the LCD display, but lights up as well.
    Cheers!
  1. Whiter Headlight Bulbs? PIAA Xtreme White?
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2011, 16:20
  2. headlight bulbs upgrade
    By grayburnett in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2011, 23:08
  3. White Headlight Bulbs
    By shaunmc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2011, 00:23
  4. Upgrade headlight bulbs?
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2009, 19:37
  5. Halfords Mega-bright (+50%) headlight bulbs half price
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2007, 22:06
