Chris NottAH Fabrications
    Nov 2011
    sunshine coast, eastbourne
    24
    Oil pressure gauge fitting...
    Evening guys and girls,
    I hoping to fit an oil pressure gauge to my 1.8t a3 but just wanted to know if il need anything to go ahead with it?
    All iv got is the gauge and the pressure sensor/sender thing, do I need anything to bolt it into the engine or is there somewhere I can bolt the sensor straight in?
    Also, where have people fitted there sensor?
    Any help would be marvellous!
    Thanks in advance
    beachbuggy's Avatar
    Surrey
    1,727
    Top of the the oil filter housing there is a spare oil adapter socket. It should just screw into there. Should be an electric one so just need to feed a wire in to the cabin
    Nov 2011
    24
    Cheers for the quick response dude, where's best to run my wire through, iv also got a boost gauge that I need to plum in aswel, is there any holes that I can poke through or do I need to drill and gromet my own hole?
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    428
    There should be some gromets on the bulkhead somewhere behind the airbox/filter. What oil pressure gauge did you get?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    There is a grommet in the corner of the scuttle next to the pollen filter (passenger side) or you can drill holes in the cap (drivers side) where the loom enters the cabin...
    <tuffty/>
  1. Fitting an oil pressure / oil temp and boost gauge...
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2013, 00:14
  2. Would like to fit an oil pressure gauge...
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2011, 10:56
  3. Oil pressure gauge/Oil pressure test
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2010, 10:58
  4. Oil pressure gauge help needed
    By Iridium in forum General Technical / How To
    Last Post: 14th March 2007, 15:57
  5. oil pressure gauge help needed
    By Iridium in forum Volkswagen and other VAG
    Last Post: 14th March 2007, 15:55
