Chris NottBadger5
    S3 Paul's Avatar
    Oct 2006
    2,764
    A strange question regarding my AFR gauge and lambda probe...
    As a precaution i fitted an innovate AFR guage to my car,
    This week im taking part in an economy run with a few of the lads i know ( see how many miles are possible between fill ups )
    The problem is... as the injectors shut off on over run i have now got a new problem ... the gauge has taken to showing a fault code of its own... Basicaly that the probe has over heated. Is this down to the lack of burnt fuel in the exhaust? as ive been off throttle on over run alot this week.
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Where have you fitted the probe?
    <tuffty/>
    Last edited by <tuffty/>; 18th November 2011 at 18:22. Reason: didn't read the post properly... DOH!
    S3 Paul's Avatar
    Oct 2006
    2,764
    Its into the cat bypass section, About 3 inch back from where the post cat lambda is.
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    humm... normally fit them a bit higher up but it shouldn't make loads of difference...
    EGT's are EGT's.... fuel or not it will be hot in there.... never known it to make a difference to any cars I have seen but Bill tends to favour VEMs gauges...
    Maybe this will help...
    "Why do I need to calibrate the O2 sensor with Innovate products?" The answer is simple Accuracy!
    <tuffty/>
  1. Finaly fitted my wideband AFR gauge...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 17:16
  2. stuck lambda probe
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 15:29
  3. lambda probe conundrum
    By kevandalice in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2010, 22:00
  4. lambda probe where is it ?
    By davidjohngarty@yahoo.co.u in forum TT/TT-S/TT-RS Forum
    Last Post: 9th November 2007, 11:16
  5. Lambda probe
    By robonmac in forum Classic Audi Forum
    Last Post: 1st April 2007, 23:25
