Chris NottAH Fabrications
    S4 Muzza's Avatar
    oww! my giant blue head!
    May 2011
    Ayrshire
    306
    Indicator Wont Flash
    The indicator on my mums A3 has stopped flashing when you put it on, just stays on as a solid light. Any ideas what could be causing this? Cheers
    Audi S4 (B5) - JUST ARRIVED :D
    Audi S3 (8L) - GONE
    Audi A3 SE (8L) - GONE
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    relay?
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    Hazard light relay - common issue
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    sounds like it could be the hazard switch relay, common fault I think most of us on here have had to replace it!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Have a look through these mate:
    Removing Hazard button?
    Indicator switch?
    2002 S3 REVO
    Carpy25's Avatar
    Oct 2007
    272
    Cool
    if its a face lift 8l like mine don't know if the early ones are the same as the switch is different , the flasher unit is in the hazzard switch , sorted mine by spraying a little (very little) WD40 in the switch and working it in by putting the switch on and off a few times, done this twice in well over a year , a new switch will sort it but its not cheap
    Rob
    edit must type quicker three posts with the same answer while i'm typing
  1. indicator light stays on but wont flash?
    By ajridermk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2011, 20:46
  2. Service indicator wont reset
    By brucer in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th February 2009, 09:50
  3. Indicator irregular flash?
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2009, 15:08
  4. Indicator lights does not flash when car is alarm!!
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2009, 10:55
  5. no indicator flash when locking!
    By TINTMASTER in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th December 2007, 16:55
Tags for this Thread
