Sky InsuranceAH Fabrications
    valentn's Avatar
    Nov 2011
    Nott's
    53
    Gearbox question
    I trying to figure out if I need new oil or the syncro is a little worn. have read that a lot of Audi boxes are a little notchy, mine struggles to go into gear sometimes but if I double clutch all is well. On one of my previous cars changing the oil solved this problem, is it possible to do it on my car or is it seales for life? Its a 1.6 A3.
    Thanks.
    macpdm's Avatar
    Jul 2011
    Cheshire
    408
    I suspect a bit of a ***** without a ramp or a pit but from a maintenance point of view I would be interested to know more.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    I had my box rebuilt but I had a leak and it looks like its coming from the gearbox! Before it was nice and smooth but since it's lost abit of oil it seems abit notchy. I'm gonna go back to midland VW (which is where it was rebuilt) so Jodi can have a look at it.. It may be good to change the oil and see if it makes any difference? Either way keeps us posted!
    valentn's Avatar
    Nov 2011
    Nott's
    53
    Quote Originally Posted by macpdm View Post
    Its not too bad, compared to my Volvo there is space to easily access the two holes, will be doing this when funds come in , hows your car going pal? Got round to changing that coolant yet?
    Quote Originally Posted by Gops View Post
    Im pretty sure a change helps out, and will report once done, found a guide just need to find time and money. Hope you get your leak sorted, mines done 150k o if it hasnt been changed its defo due. Box is silent though which should mean there isnt too much damage.
  1. gearbox question
    By tara_nta in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2010, 21:46
  2. gearbox question
    By raver100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2009, 19:08
  3. Gearbox question
    By justin3779 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2009, 10:43
  4. 3.0 gearbox question
    By niftyandy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2009, 14:18
  5. B6 S4 Gearbox Question
    By S43MTC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2008, 02:28
