Sky InsuranceChris Nott
Results 1 to 11 of 11
    Jul 2011
    middlesbrough
    112
    a3 throttle body fault code?
    Hi there as you may know got a a3 1.8t agu engine code every time i plyg vagcom in this fault appears? I clear it then every time i plug the computer in its back on, is this a common problem?
    17967-Throttle Body (j338) Fault in basic settings
    P1559 - -35-00-
    Regards Tom
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,077
    Have you re aligned it, not sure if you can do it with VCDS as yours is a cable throttle?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    I have a S3 one if you need it?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    AGU is cable yep.
    I've had mine off and never had any issues after with having to realign it etc.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Jul 2011
    middlesbrough
    112
    i have never had it off, but has always thrown this code off, its cable operated how do you re aline them? why do they need it?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,236
    Vagcom. There is a video on here showing how to do it.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Jul 2011
    middlesbrough
    112
    ah right, any one got a link on how to do it? i have a copy of vagcom
    regards tom
    Sep 2012
    25
    Hi guys my agu has just devolved this fault. My battery died when we had the snow and when I went to start it again problems with reving etc local garage said it was limp mode so a local garage told me a way to rest it luckily it worked but when I drove it it has no boost and when they plugged it in they said it has a fault code saying throttle bodies fault in basic settings they have no idea. Did you manage to get it resolved???
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    405
    I had this fault with mine after having the battery off for 2 months and it turned out the potentiometer had decided to give up unfortunately this is built in to the throttle body I got one of eBay for £25 posted and this resolved the problem instantly the plug on my throttle body was different to the new one but they still work with a very simple mod to the plug pm me if you get this problem an I will tell you what to do hope this helps lee
    phil miller's Avatar
    Sep 2012
    Devon
    843
    TB Adaption is easy, go in to vcds, then meas blocks 060 or 098 (cant remember without looking) then switch to basicsettings, top right box will say OK once it does, back to measuring blocks and done, clear codes, all sorted
    Sep 2012
    25
    Sweet thanks guys. I have another question. Will this problem cause my turbo to not boost at all???.
  1. Throttle problems/ vag com fault code
    By s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2013, 21:33
  2. a3/s3 throttle body,
    By spencerdale in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2010, 20:21
  3. Where is the throttle body on the S3?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2010, 19:22
  4. throttle body
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th March 2007, 19:14
  5. Throttle Body
    By imported_Cali in forum General Technical / How To
    Last Post: 22nd July 2004, 22:40
