Chris NottMonster Motorsport
    Apr 2007
    Surrey
    235
    Strange noise from air con
    Hi. Left for work this morning, car was fine. Stopped for petrol and when I started driving I noticed a strange noise that increased and decreased with the revs. It's like a whining / whistling noise but quite loud. The noise stops if I put the air con into econ mode which makes me think the compressor has had it. The fact that it stops when in econ mode makes me think that the clutch on the compressor is still engaging and disengaging. Anyone else had similar issues?
    2003 S4 Moro Blue Saloon
    Jun 2003
    west yorkshire
    90
    I have same sort of noise, seems fine when first started but when turned off for half hour or so when restarted air con makes a loud rumble type noise for a couple of minuets then quietens down, I was thinking it could be the bearing, not sure if the bearing can be changed on its own or if its a new compressor, been meaning to get it sorted but now with the winter coming I won't be using the air con much, but if anyone else knows if the bearing is replaceable it would be a great help.
    Sep 2011
    49
    I have a noise from my Aircon in the passenger footwell a strange bubbling gargling noise
    Nov 2011
    85
    Hi, only had my car a week now & mine makes the same gargling bubbling sound from passenger footwell. Is this normal??
    Steve
    Sep 2011
    49
    Not sure what it is think it Ights be just the Aircon gas flowing I'll get it drained and try again
  1. Air con...very bad noise
    By cerbera4_0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2010, 21:42
  2. Another strange air-con problem.....
    By Jimmyboy in forum Air Conditioning
    Last Post: 8th February 2010, 17:55
  3. Got a strange squeak when air con on
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2009, 15:26
  4. Very strange air-con problem...
    By Brad89 in forum Air Conditioning
    Last Post: 28th June 2009, 19:04
  5. Very strange air-con problem!
    By Brad89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2009, 18:04
