EM TuningBadger5
Results 1 to 19 of 19
    May 2010
    224
    Water pump changed, now my temp wont go past 70, also heating is not so hot
    Ok so had my water pump changed, whats key to point out, is the unit which was removed, 3/4 of the plastic fan was broken, as in shattered, quite lucky i got the pump changed when i did
    Anyway had a new water pump fitted, but now the tempreture wont raise above 70, also the heating is not as hot as it once was. I changed the coolant temp sensor last year. Is my themostate stuck open? Previously the car would heat up quickly and not budge from 90, no doubt due to a reduction in coolant being pushed through the engine.
    thanks guys
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    Sounds like a faulty thermostat to me!
    TD5 Land Rover Defender build
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    +1 for a broken thermostat
    cheap easy fix
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by jay1601 View Post
    cheap easy fix
    ....If you have midget hands on the end of long skinny arms and 72 different knuckle adaptor pieces in your socket set..
    But I agree, sounds like the t'stat to me.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    May 2010
    224
    Yeah as predicted, nice one, spoke to my mate who fitted the pump and said the same thing. Also, if you havent had your water pump changed, and your sitting on 60k miles, get a new one fitted asap! Dont run the risk. Well, all my blame is on audi who at 50k changed the cambelt but not the water pump. Will post a pic up eventualy of the shredded fan.
    Does anyone have a how to guide on changing the themostat, iv seen a coolant temp sensor one doing the rounds
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    Quote Originally Posted by beanoir View Post
    i'm good with my hands have the right tool for the job
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Bit late now, but it's always worth changing the stat when the pump is out.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by drfeelgood View Post
    Here you go chief, this is the one I used.
    Thermostat replacement procedure..>> - AudiWorld Forums
    May 2010
    224
    This looks awfully fiddly, might just book it in!
    Westy's Avatar
    Dec 2008
    17,283
    Fiddly it is, and rather frustrating if you have a short temper! I launched half my socket set in a rage trying to do this
    S3 Build Thread
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    You'll be clearing up more blood than coolant I assure you.
    May 2010
    224
    Well, as mad as this sounds, its going to cost less to have someone do it then myself. When you consider the tools, i would need to buy a half decent socket set, around 70 quid, then coolant, then the themostat, then the dip stick holder will snap i bet, so one of them , then 3 to 4 hours of my saturday getting cold and cut up...
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    takes about 20 mins to fit tops.
    even a cheap tool set will do the job.
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    No kudos there, man up and grow some FFS this is ASN not playskool, I want to see your hands shredded to pieces....if I suffered then so should you!
    Westy's Avatar
    Dec 2008
    17,283
    20 mins! Not on an S3 it dont.
    S3 Build Thread
    May 2010
    224
    Iv cut my hands enough over the year on this car, coolant temps, gloveboxes, front bumpers, wheel arch liners,head lights, ...i want an easy life dammit...and to be able to sleep in on saturday lol
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Thats fair play, i'm kidding anyway. It's actually a PITA of a job, and like you say if you need to buy more tools to do the job then it does beg the question of whether or not to just spend the cash and get somebody else to do it. Although, buying the tools is a good investment for future...
    Speaking of gloveboxes, my numpty brother broke mine the other day when he was "helping" me wire my speakers up. I've a right mind to lock him in it until he coughs up for a new one.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    don't buy cheap tools IMO
    "Stick a V8 in it!"
    15,390
    The way i've always worked is if a job needs a tool, i'll buy it. Ok it means the job might not then cost a huge amount less than paying someone, but that tool is then mine to sit in the toolbox. Once you've got a decent socket set and a few other choice bits you'll find you have most of what you need to do any job on the car. While that means the first few jobs you do might cost a fair amount, the work quickly gets cheaper.
  1. Changed my water pump!!!
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2011, 14:36
  2. car wont rev past 1500rpm
    By rydinator in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2011, 16:23
  3. No hot water getting into the heating system? What can it be
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th December 2010, 18:09
  4. Replies: 4
    Last Post: 3rd December 2010, 10:18
  5. A3 1.8TS - Should water pump be changed with timing belt?
    By SMc in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2007, 11:36
